"Mini" resistors?
oozitron
solder fume huffer
"Mini" resistors?
Post by oozitron » Sat Nov 28, 2020 8:41 am
Are there any drawbacks or issues with these "mini" resistors?
https://www.digikey.com/en/products/det ... K0/9770246
They are much less expensive... basic specs look the same as the normal sized metal film resistors.
Andrew
Never want to come down, never want to put my feet back down on the ground
Synthbuilder
Re: "Mini" resistors?
Post by Synthbuilder » Sat Nov 28, 2020 11:31 am
They should work just fine. The smaller size does lead to increased self heating when current is passed which increases drift. However, this is likely to be insignificant in any of my circuits.
It's usually worth buying resistors in 100s as this greatly reduces costs. From Mouser the standard resistor I use is less than 2c a piece when bought in 100s, eg. 603-MFR-25FTE52-82K .
Tony
