Intellijel Shifty
kisielk
Re: Intellijel Shifty
Post by kisielk » Tue Feb 23, 2021 12:43 pm
Usually the best way is to just adjust the tuning of the oscillators so the available range works. Often you won't be using more than 3 or 4 octaves anyway so you don't need a full 10 octave range at once. If that's not possible you can always sum the output with a static voltage offset.
Intellijel R&D
1n
Post by 1n » Fri Mar 19, 2021 9:58 am
Pitch out > Shifty > Rings / Mimeophon (osc mode) / Beads (wavetable). Shifty outs 1 and 2 (Rings and Mimeophon) take the distributed signal at expected pitch (same as without 1v), but out of 3, the pitch of Beads rises a couple of octaves with 1v signal in (attenurandomizer at 12). Attenuation/offset works, of course. Might the tuning issue discussed above account for pitch ?
The pitch issue is the same for any source.
Edit: Thanks @Pichonettes for sorting this out. A pitched signal from the same source sent to a module and then input into Beads adds voltage, raising pitch of Beads.
Input from Enigma (Turing Machine Volts expander) for Benjolin v2 produces a similar effect in Beads (wavetable).
Beyond all that fuss based on my lack of knowledge about voltages, Shifty is a beaut - turns a small system into an dynamic orchestration machine.
1n
Post by 1n » Tue Mar 30, 2021 4:00 pm
deleted - wrong question
