Hi guys I have a question
I recently got a 4 pot joystick at a surplus place and was thinking I might be able to build up two barebones choices kits to build a dual parallel joystick module for myself, basically everything twice as I have one more sets of pots moving in the same way
the pots are measuring around 18k on this thing is there any chance components can be swapped out on the bare bones kit as I am aware it's designed for 100k pots
thanks
Chris
choices joystick potentiometers
Moderators: Kent, flight, computer controlled
WTB: any Digisound80 / Digisound 80 faceplates/pcbs/kits.
- Tombola
I have never seen the schematic for the Choices joystick, but I would *imagine* the pots will be set up as voltage dividers.
If so, the change from 100k to 18k shouldn't make any difference to the circuit at all, assuming they're both linear.
Ken Stone's joystick module page has some other suggestions: http://www.cgs.synth.net/modules/joystick.html
- ersatzplanet
- Synthwerks Design
You should be able to use any pot in the voltage creating peer - the choices also processes signals directly and that side of the circuit might be more finicky. The only advantage of using this dual action is if you want to have different ranges on the same axis or inverted action but I would imagine that an inverter or a scaler coddle would be cheaper (or as cheap) than two joystick circuits - and a lot more flexible.
-James
