Consumes: 30 mA of +-15 and 150 mA of +5.
Plate Voltage: 48 volts
Size: 1 single space MU module compatible with Synthesizers.com cabinets and rails.
Depth: 2"
Tube used: NOS 5725 pentode
Tube sticks out from the front panel about 1"
Panel: 3mm thick anodized aluminum with high quality engraving
Delivery time: 3-4 weeks. Often less.
Available now with all parts in stock accept for the panel, the panel is ordered on demand and takes 1-2 weeks to arrive.
Price is $385
click here for more information
This one has different "color" than the VCA but still has a similar behavior.
Like the VCA, it isn't an obliterating distortion, but it isn't subtle either,
An ideal use is to combine 2 audio sources with the Haxor then feed the output into a filter or VCA or any other effect that looks appealing.
Smack the CV input with gates, pulses and triggers to make the Vactrol pop and click in rhythmic patterns.
Sounds:
Two Unkle Oscillator squares into ze Haxor
Unkle Saws with phase modulation into ze Haxor
Wretch Machine oscillators direct outs into Haxor
Wretch oscillators into Haxor then into Destructor Beam
