Questions about Power
ThatFunnyLookinGuy
Post by ThatFunnyLookinGuy » Thu Nov 26, 2009 10:13 pm
Has anyone ever had problems with modules drawing more milliamps than a power supply is rated for? Also, how much current do modules draw when not being used?
wetterberg
Re: Questions about Power
Post by wetterberg » Fri Nov 27, 2009 3:09 am
ThatFunnyLookinGuy wrote:Has anyone ever had problems with modules drawing more milliamps than a power supply is rated for?
Plenty have, yes. Then you're likely to hear modules behaving funny as they're starved of power.
Remember you can use modular planner to calculate how much power you'll be needing in a given case.
ThatFunnyLookinGuy wrote:Also, how much current do modules draw when not being used?
about the same as when used, if I'm not mistaken.
Post by Kent » Fri Nov 27, 2009 3:58 am
Actually, it depends upon the module. Drum modules draw almost nothing when not firing their sound. It's a bit like asking how fast a car can go. It depends upon the design.
fonik
Post by fonik » Fri Nov 27, 2009 4:59 am
depends. if the module has LEDs the current draw depends on their status. if the module has to provide power to subsequent modules it changes too, but that would depend on even the subsequent module.
Big Boss at fonitronik.de
Tech Buddy at Random*Source/Serge
decaying.sine
Broken <--> Fixed
Post by decaying.sine » Fri Nov 27, 2009 6:57 am
If you aim for 70-80% of psu amp rating, is this conservative enough to not worry about power starve or other issues? Or, is that too conservative?
Post by Babaluma » Fri Nov 27, 2009 7:08 am
sounds like about the kind of conservatism i aim for in my psus. better to be under than over. and the current draw changes depending on which module is plugged into which, so it's impossible to give a "general figure".
Fidgit
Post by Fidgit » Fri Nov 27, 2009 7:34 am
play it safe here, don't overload your power supply. :!:
fonik
Post by fonik » Fri Nov 27, 2009 7:50 am
what i observe not only in this forum is the tendency to be tight with frontpanel space and cabinets and all the supplementary stuff in general.
however, i can understand that people rather want to spend their money for sound making modules than for these boring cases, cabinets and PSUs, which don't make sounds, but add weight... am i wrong here?
wetterberg
Post by wetterberg » Fri Nov 27, 2009 8:25 am
@fonik, I think it's more a factor of people not wanting to hook up PSUs themselves. I can dig that.
FWIW my next case will have a 10-amp PSU in it, and it'll power more or less my entire modular studio.
Post by Babaluma » Fri Nov 27, 2009 8:37 am
i've always tried to be conservative. i don't know if it's true, but i once read that if you over-tax your power supply, then it can overheat, leading to a shortening of its life and a possible fire risk. not to mention things such as module instability. i'd much rather my modules had all the juice they need, than risk anything.
i run a blacet rig with four blacet ps500s, and the average on each one is about 450mA. that's a very conservative estimate, with a conservatively rated power supply.
fonik
Post by fonik » Fri Nov 27, 2009 8:39 am
wetterberg wrote:FWIW my next case will have a 10-amp PSU in it...
10A! wow. what do you use?
decaying.sine
Broken <--> Fixed
Post by decaying.sine » Fri Nov 27, 2009 9:10 am
wetterberg wrote:10-amp PSU
:eek:
That must weight a good 20-30 pounds.
I picked up two NOS power-one 3.4 amp for +/- 12VDC. They were only about $40 each on ebay. I decided it was time to sell the a100g6's that I have and build my own case and supply with STG distro boards.
wetterberg
Post by wetterberg » Fri Nov 27, 2009 10:35 am
I think it's one of the bigger Power One supplies. And yeah, that'll power about 1000HP, hehe.
lemme quickly throw in a couple of these:
:sb: :sb: :sb: :sb: :sb:
Fidgit
Post by Fidgit » Fri Nov 27, 2009 12:59 pm
the PSU in the rear provides 10A of "power one" power. it's apparent that it works with 2 PSUs (HDD15-5-A) in parallel plus a hidden, little switched PSU for +5V.
ThatFunnyLookinGuy
Post by ThatFunnyLookinGuy » Fri Nov 27, 2009 1:52 pm
I've got a Lexington on order and the Monorocket site says that the case contains four 1 amp power supplies. Does this mean that 1000 milliamps is split between two bussboards on each level of the case?
wetterberg
Post by wetterberg » Fri Nov 27, 2009 2:01 pm
Actually I think they're all connected together as one big 4amp device, which is then distributed to all the bussboards.
