FoH POWER and 1-6-13 Bus Board
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
johnnylonz
Post by johnnylonz » Thu Jan 16, 2014 6:18 pm
Hi,
I've got a small system powered by the FoH Power and 1-6-13 bus board combo. I think both of these are discontinued, but am wondering if someone could help me out:
I'm trying to gain a little HP in my system, and the FoH Power module is a 10HP so I'm hoping I can swap it out with a thinner module but keep the bus board. Would I have any problems if I swapped it out with something like a TipTop Zeus Access and just connect the terminals on the access to the 1-6-13 bus board? It seems like it would work but I don't want to accidentally blow something up.
Any help would be much appreciated :hail:
HeWhoWantsJeans
Post by HeWhoWantsJeans » Sat Jan 18, 2014 1:04 pm
I see absolutely no reason why the board wouldn't be compatible with another power source. It was intended as a drop-in upgrade for Doepfer cases, for instance.
I've archived over 400 answering machines, and the best of which is constantly updated on Tumblr. Public domain! Enjoy! Donate, too!
http://answerphone.tumblr.com/
johnnylonz
Post by johnnylonz » Sat Jan 18, 2014 1:58 pm
Thanks, that's what I was hoping. Of course in looking at the Zeus access again, it appears to be designed for boards with power built in. Anyone have a suggestion for a thinner power module?
HeWhoWantsJeans
Post by HeWhoWantsJeans » Sat Jan 18, 2014 2:52 pm
Edit: duplicate post. Removed the original. The clone lives on!
Last edited by HeWhoWantsJeans on Sat Jan 18, 2014 2:52 pm, edited 1 time in total.
HeWhoWantsJeans
johnnylonz wrote:Thanks, that's what I was hoping. Of course in looking at the Zeus access again, it appears to be designed for boards with power built in. Anyone have a suggestion for a thinner power module?
Ah. The Zeus Access requires a Zeus Studio Bus to be the first board it is connected to, as the unit itself runs on a 15VDC external power supply, which the Studio Bus then converts into bipolor 12VDC.
You could convert a uZeus into a supply for any passive board (such as the 1-6-13), though. I would wager that, as long as you converted the male headers into female headers and had the pins lined up correctly, it could power, as the uZeus has an additional circuit board that does the DC conversion.
Caveat: I have no experience with the uZeus product so you may want to ask Gur at TipTop about that idea.
Also a thought - if you're not adverse to DIYing, I've seen people mount POWER modules on the inside of the case just fine. As someone who loves to build using what they have already on-hand, that's what I would probably do. If it'd help you measure out where to drill the holes, I'll contact flight about getting a mechanical drawing of the panel.
johnnylonz
Post by johnnylonz » Sun Jan 19, 2014 5:49 pm
Thanks for all the info. I think I might try mounting it in my case, I'm not very handy but after hearing your suggestion and looking at it I think it's do-able.
Thanks again!
HeWhoWantsJeans
Post by HeWhoWantsJeans » Sun Jan 19, 2014 10:52 pm
johnnylonz wrote:Thanks for all the info. I think I might try mounting it in my case, I'm not very handy but after hearing your suggestion and looking at it I think it's do-able.
Thanks again!
Excellent. If you have any questions, please don't hesitate to ask. I'll answer them to the best of my ability and I'll do my best to gain the attention of the floating gun-spitting head of Flight of need be. :tu:
causticlogic
Location: atop Unknown Kadath seeking the Ultimate Gate
Post by causticlogic » Mon Jan 20, 2014 2:15 am
HeWhoWantsJeans wrote: I'll do my best to gain the attention of the floating gun-spitting head of Flight if need be.
I hear he's partial to grain. maybe offer him some.
RealDudes wrote:there's only one window in my padded cell and all I can see is a hallway
looks like there's blood on the floor again
Bumply wrote:I just want to leave work right now and listen to a nice triangle wave.
Return to “Flight of Harmony”
