VERBOS ELECTRONICS
Sanys
Post by Sanys » Sat Aug 03, 2019 10:51 am
sick!
Prunesquallor
Post by Prunesquallor » Sat Aug 03, 2019 10:56 am
MODS: Can we split this thread? It's too large to load all the pages to search through effectively. :bang:
If at first you don't succeed read the instruction manual.
RIP Ziggy, the companion in my avatar.
BrokenBo
Post by BrokenBo » Sat Aug 03, 2019 11:30 am
any more reviews on the Control Voltage Processor?
advrsry
Post by advrsry » Sat Aug 03, 2019 1:55 pm
Prunesquallor wrote:MODS: Can we split this thread? It's too large to load all the pages to search through effectively. :bang:
Probably makes sense to break out new threads for modules. Splitting this thread is probably too much work.
Prunesquallor
Post by Prunesquallor » Sun Aug 04, 2019 1:18 am
How so? Split it after a sensible number of pages and call the first bit Part 1 and the second Part 2. I don't know what the upper limit on pages should be, but my new and well-specced PC struggles at around 100 pages, and 90 seems to be OK.
advrsry
Post by advrsry » Sun Aug 04, 2019 4:02 pm
You can browse by page if you are reading in order, and use the forum's search functionality if you want to find a post.
Prunesquallor
Post by Prunesquallor » Mon Aug 05, 2019 2:44 am
Are you kidding? Browsing by page through a thread this long takes ages, and the search functionality is not that great. It's far more efficient to load all pages and hit Ctrl F. What's the problem?
synonymist
Post by synonymist » Mon Aug 05, 2019 5:59 am
Prunesquallor wrote:Are you kidding? Browsing by page through a thread this long takes ages, and the search functionality is not that great. It's far more efficient to load all pages and hit Ctrl F. What's the problem?
The problem is the antiquated forum software:
<div align="center"><span class="copyright">Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> &copy; phpBB Group </span></div>
Prunesquallor
Post by Prunesquallor » Mon Aug 05, 2019 6:37 am
Thanks for that response! OK, maybe it's a question of waiting for this to be resolved, then.
Nutritional Zero
Post by Nutritional Zero » Mon Aug 05, 2019 8:05 am
Image[/url]
youkon
frequency research department
Post by youkon » Wed Aug 14, 2019 2:36 am
"Melodic" Jam with my Verbos System.
A Dynamix was added for further vca duties. Pairs really well soundwise.
This patch was inspired from the verbos youtube random sampling "follow melody" patch
rayultine
Post by rayultine » Wed Aug 14, 2019 10:28 am
Anyone have info on the "redesigned" aka smaller ATC that popped up on modulargrid?
damase
Post by damase » Wed Aug 14, 2019 11:00 am
rayultine wrote:Anyone have info on the "redesigned" aka smaller ATC that popped up on modulargrid?
it was presented at superbooth. no more vactrols, but still sounds amazing. 10hp. no info on release date that i know of
slowpilgrim
Post by slowpilgrim » Wed Aug 14, 2019 12:50 pm
I added it to use in a rack plan, no further details.
Sanys
Post by Sanys » Wed Aug 14, 2019 6:16 pm
shanebroderick
Post by shanebroderick » Thu Aug 15, 2019 1:10 pm
Does anyone use Disting as their main quantizer in a Verbos system?
I'm about to order the Multistage and plan to use it for melodic sequencing.
damase
Post by damase » Thu Aug 15, 2019 1:55 pm
shanebroderick wrote:Does anyone use Disting as their main quantizer in a Verbos system?
Intellijel Scales here
not my business really but disting seems about as opposite of philosophy and workflow to verbos as you can get
yellowecho
Post by yellowecho » Thu Aug 15, 2019 2:24 pm
Most of the time I don't use a quantizer with my Verbos system... I just use the CV attenuator to limit the range of the voltage.
mritenburg
Post by mritenburg » Thu Aug 15, 2019 2:51 pm
Which ever quantizer you choose, you should verify that it operates in a 0-10v range. Don't get stuck with a quantizer that only operates in a 0-5v range, otherwise, you'll be chopping your Verbos cv range in half.
Disappointment with any module is usually a failure of imagination.
This and That
stephentrask
Post by stephentrask » Thu Aug 15, 2019 3:08 pm
I use a Pico Quant. It's pretty no nonsense and keeps all the attention on the VMS.
i don't know what I'm doing but I sure like doing it.
BrokenBo
Post by BrokenBo » Thu Aug 15, 2019 11:19 pm
one should use an attenuator before going into the quantizer (or are there any quantizers with built in attenuation to limit the octave range?) as the VMS has 0-10V range, which means 10 octaves.
so far i only went directly into the cv attenuators of the HO or CO when i wanted to use the vms for pitch.
shanebroderick
Post by shanebroderick » Thu Aug 15, 2019 11:53 pm
BrokenBo wrote:one should use an attenuator before going into the quantizer (or are there any quantizers with built in attenuation to limit the octave range?) as the VMS has 0-10V range, which means 10 octaves.
I think the disting mk4 offers a dual quantizer with attenuation in 4hp which I need and was why I was asking. Not sure how good it works though.
kingcons
Post by kingcons » Fri Aug 16, 2019 9:14 am
Just got the delivery notice on my first ATC to pair with my CO and Scan and Pan. When is work over again? :hyper: :hyper: :hyper:
thetwlo
Post by thetwlo » Fri Aug 16, 2019 6:33 pm
mritenburg wrote: Which ever quantizer you choose, you should verify that it operates in a 0-10v range. Don't get stuck with a quantizer that only operates in a 0-5v range, otherwise, you'll be chopping your Verbos cv range in half.
Thanks! weird, the WMD Arpitecht is only 0-5v, didn't notice that before. I wonder if a firmware update could change this?
bayrumblues
Post by bayrumblues » Sat Aug 17, 2019 11:10 am
wonder when Verbos is going to release cases for the keyboard/ black horse/ full systems? Been waiting years!
