VERBOS ELECTRONICS
johny_gtr
Post by johny_gtr » Fri Oct 04, 2019 10:25 am
damase wrote:if you buy new from a dealer, you should be getting the latest revisions. you also get the ability to return if there is an issue
if youre worried at all, this is what id recommend. ive had great experience buying verbos from Detroit Modular, i had issues with a Scan and Pan, Dan confirmed it and accepted my return without hassle
I hope so,
anyway maybe dealers should provide their QC before sending modules if there well-known issues. All these things sound weird after communication/work with MU builders.
modular percussion and scapes - http://ovod.bandcamp.com
mu modular space electronica https://7k-ok.bandcamp.com
Godphaser
Post by Godphaser » Fri Oct 04, 2019 11:40 am
The PCB should have the number 102816, latest revision is post late 2016.
mritenburg
Post by mritenburg » Fri Oct 04, 2019 12:03 pm
Godphaser wrote:The PCB should have the number 102816, latest revision is post late 2016.
You might also seek out the rev 1 modules that were hand assembled before Verbos bought their pick-and-place machine. I have rev 1’s and never had any problems with them.
Disappointment with any module is usually a failure of imagination.
a loose reference
Godphaser
Post by Godphaser » Fri Oct 04, 2019 12:11 pm
Rev1 have ceramic capacitors, the whine drove me insane.
Also put a Rev1 next to a later version, you might notice a pretty huge sonic difference.
mritenburg
Post by mritenburg » Fri Oct 04, 2019 1:43 pm
Godphaser wrote:Rev1 have ceramic capacitors, the whine drove me insane.
I haven’t experienced any ‘whine’ as you call it, but I also use true linear power supplies. I steer clear of switching supplies. Also, my rev1 DFP has much deeper resonance that what others have described/shown in examples.
Godphaser
Post by Godphaser » Fri Oct 04, 2019 10:58 pm
The power supply might be the explanation but still, newer revisions don't have that issue.
Paul_N
SchneidersLaden / Verbos event
Post by Paul_N » Mon Oct 14, 2019 9:36 am
This was from a few weeks ago -
Verbos Systems for Beginners:
[video] [/video]
Advanced Patching:
[video] [/video]
A lot of the advanced stuff already appeared on the Verbos channel in the past, but it was nice to hear Mark go through his thought process. Mark’s improvisation at the end was interesting; the waves reminded me a lot of Cianni.
Tumulishroomaroom
Re: SchneidersLaden / Verbos event
Post by Tumulishroomaroom » Mon Oct 14, 2019 10:50 am
Paul_N wrote:This was from a few weeks ago -
[video] [/video]
Advanced Patching:
[video] [/video]
Fixed your links. And yes, quite interesting. I think I'm going to get a Sequence Selector once and for all, such a open module; he was basically using it in every patch. I really liked the wave switching and delay taps feedback tricks. But I don't have a sequential switch.
instagram
soundcloud
dc11 - electron out on Cosmic Wave Records.
doublestewart
Post by doublestewart » Mon Oct 14, 2019 11:22 am
Thanks for posting these. +1 on the sequence selector, I love the flexibility it provides as a sequencer, switch, transposer. And I actually use the buttons on the bottom much more than I was expecting. It pairs so well with all of his other modules.
Tumulishroomaroom
Post by Tumulishroomaroom » Mon Oct 14, 2019 3:40 pm
Do you use it on it's own ? I'll be waiting for one to pop up used and grab it.
instagram
soundcloud
doublestewart
Post by doublestewart » Mon Oct 21, 2019 3:52 pm
Tumulishroomaroom wrote:Do you use it on it's own ? I'll be waiting for one to pop up used and grab it.
I'll use it by itself in a pinch if I need another sequencer, or as I mentioned I'll play it using the buttons for very simple sequences. I use it with the multistage the most, to make it a 16 step sequencer or to transpose a sequence. If i'm using my other case at the same time I'll often bring in the Rene and/or voltage block for even more sequencing options.
Getting one second hand sounds like a good plan, they are on the pricey side.
advrsry
Post by advrsry » Tue Oct 22, 2019 8:19 am
Unfortunately neither the Seq Selector nor Control Voltage Processor pop up
often on the second hand market.
doublestewart
Post by doublestewart » Tue Oct 22, 2019 10:39 am
True, that's the case with pretty much all Verbos modules. I had to wait a long time before I was able to get a random sampling.
belsina
Post by belsina » Sat Oct 26, 2019 12:54 pm
Triglav wrote:I also have a rev5 and after much wiggling I was able to get rid of the DC leak and have a nice resonance.
(..)Adjust the corresponding trimmer until it reads 5.6V. Repeat for the other 3 pads/trimmers. You might have to go through it a couple of times before they are all stable.
Max value at TP1 trimmer is 5.35V. Trimmer is full ccw. :despair:
All other trimmer seems normal.
Rev5 with Doepfer PSU2 with minimal DC leak when LPF is closed.
Below the line my DPF sounds fantastic.
Euro Trash Bazooka
Post by Euro Trash Bazooka » Wed Oct 30, 2019 11:33 am
I can buy an HO that's unused for a good second hand price right now. PCB has 110915 written on it, so not the last rev. Should I still go for it?
I've already had to send some 2nd hand Verbos modules back to them for recalibration, I know the ordeal it can be. At this point I'd rather wait for a good version than a lesser one.
Thanks a lot for your input!
mritenburg
Post by mritenburg » Wed Oct 30, 2019 12:05 pm
belsina wrote:
Triglav wrote:Max value at TP1 trimmer is 5.35V. Trimmer is full ccw. :despair:
How are your front panel controls set? For the calibration procedure, resonance should be fully ccw and frequency should be fully cw.
The full procedure is in the DFP discussion.
a loose reference
belsina
Post by belsina » Wed Oct 30, 2019 12:39 pm
Front panel settings was as described in Triglavs post.
Problem is fixed by Verbos Customer Service. :yay:
GreenPiece
Post by GreenPiece » Thu Oct 31, 2019 8:25 am
Just sold my harmonic oscillator. It's a beautiful module and it was really hard to part with. I had issues with 1v/oct tracking using my Moog Grandmother as a controller. Just wanted to note this for anyone using a similar setup.
I couldn't really gel with it personally but really wanted to since I think it's one of the more unique modules available in Eurorack. I believe if I wanted to go down this path again I would consider a Dreadbox Antiphon which appears to have similar functionality albeit less.
Anyways, Happy Halloween all!
Euro Trash Bazooka
Post by Euro Trash Bazooka » Thu Oct 31, 2019 8:46 am
GreenPiece wrote:Just sold my harmonic oscillator. It's a beautiful module and it was really hard to part with. I had issues with 1v/oct tracking using my Moog Grandmother as a controller. Just wanted to note this for anyone using a similar setup.
I don't know, I guess Verbos modules probably aren't the best when it comes to getting perfect results all the time. To me it's more about "taming the beast" and kind of hope for a great result. It usually works as far as I am concerned but I don't think I'd expect from Verbos modules to always be precise and easy to control all the time. Kind of sad really, but also part of their charm to me. They sound gorgeous but are too experimental by nature I suppose.
Anyway, I sent the payment for mine this morning. It's still under warrantee and I have the receipt so if there's anything wrong with it I'll be covered.
damase
Post by damase » Thu Oct 31, 2019 8:53 am
i got a HO recently, module from 2018
it is not the easiest oscillator to calibrate... by this i mean its very easy to access the hole on the front and calibrate it up to be very accurate... but i turn my modular on the next day, and its not as perfect as i made it the previous attempt so i have to do it again. this wouldnt be as much an issue but with all those sine waves and just temperment flying around a patched up system it can be hard to tell if its out of tune or not sometimes
its good enough, i just wish i could keep it as perfect as i dial it in. maybe ill find the sweet spot soon. i notice it needs a nice warm up time and still drifts very slightly over time also
beautiful module though i do really love it
mritenburg
Post by mritenburg » Thu Oct 31, 2019 10:22 am
Some challenges with calibration of analog oscillators to take into account:
1. Let your oscillator warm up for at least 20 minutes before attempting calibration
2. Check both + and - rails of your PSU. Make sure they are both outputting +/-12v
3. Consider the ambient temperature of the room in which you keep your modular. If the temperature fluctuates from cold to warm/hot back to cold, it is going to knock your oscillators out of calibration
4. Understand that professional musicians who use modular gear will calibrate their oscillators before every recording session
5. Consider your voltage reference source. If you calibrate your oscillators to a specific cv/gate keyboard or MIDI-CV interface, it is really only calibrated for that voltage source. Your oscillators will usually need to be re-calibrated for the voltage source you use. For instance, if you decide to use a specific quantizer, you should calibrate to that quantizer
6. Melodyne works extremely well with monophonic analog sources and can transparently correct pitch issues related to calibration.
damase
Post by damase » Thu Oct 31, 2019 10:48 am
thanks, and very good points, some of which i was not taking into account when i tried.
i didnt want to sound as if this is a ‘huge’ problem for me at all, just an observation in comparison to a very accurate oscillator i have(omega phi needs no adjustment ever). the drift i refer to is within a couple cents... its very acceptable
mritenburg
Post by mritenburg » Thu Oct 31, 2019 10:54 am
damase wrote:thanks, and very good points, some of which i was not taking into account when i tried.
Oh definitely, I wasn’t calling you out, I just saw an opportunity to add to the discussion about calibration as it is often a source of frustration for many (most?) wigglers.
thebends9
Post by thebends9 » Sun Nov 03, 2019 7:27 pm
advrsry wrote:Unfortunately neither the Seq Selector nor Control Voltage Processor pop up
viewtopic.php?t=223628
Nutritional Zero
Post by Nutritional Zero » Sun Nov 03, 2019 8:29 pm
I can’t really handle all the unquantized pitches flying around in the Verbos demos. It makes me wonder whether I’m a really uptight “musician” or whether some engineer has an undiagnosed tin ear. Man that is some brutal listening, as much as I appreciate the lineage and directness of these modules.
