Was just thinking about how you would bring in an external pulse into the new Easels? I have a CVGT for converting euro triggers to Buchla pulse, is there any way of getting this pulse into the easel e.g to trigger the sequencer, pulser or envelope other than by plugging it in the pulse input at the bottom left (where you would normally plug the pulse out from the keyboard).
I had an idea i could pulse the sequencer, for example, with a euro clock, and simultaneously play the easel keyboard and still use its pulse out to trigger the envelope. But i would, i think, need another place to input these two different pulses.
Could this be done perhaps via one of the "to prog" inputs.
for example: Euro trigger (converted to Buchla pulse by CVGT1) to "to prog" and then using the program cards route the "to prog" to trigger the envelope. I guess its this last bit that i wonder about? is this possible?
Small pic below of possible program card wire (assuming on Easel you have the external pulse going in the Inverter's "to. prog"):
