Analogue Systems RS390 cannot run Doepfer case . ???
Author Analogue Systems RS390 cannot run Doepfer case . ???
pulse3000
Hello
I am trying to use RS 390 echo module on Doepfer case but unfortunately it is not working.
I am using a custom made AS to Doepfer Case power cable .
The other module RS 440 delay is able to run with this method but unfortunately RS 390 not.
Can it be that Doepfer case has not enough power to run it ?
I will be very happy if someone can address this issue .
thanks a lot
Malekko
It may need the +5V. The Doepfer case does not supply that, if so you'll need to get an adapter from AH
pulse3000
i also checked with this but couldnt work .
But in logical way AS cases also cannot give more power than Deopfer bus equipped with 5V adapter isnt it ?
So logically it should work with adapter .
REwire
I have an RS-390 in a Doepfer case. It won't work without that AD-5. Asys cases have this built in, not Doepfer seriously, i just don't get it
