I need help: drawing a wave multiplier circuit w/ rectifiers
Author I need help: drawing a wave multiplier circuit w/ rectifiers
Blackened Justice
Okay, so some time ago I had an idea for a module (please don't tell me it's not original, I realize it may not be), please see the original topic: https://www.muffwiggler.com/forum/viewtopic.php?t=7847&highlight=recti fiers+modules
So, I need help in actually moving this project forward. I have absolutely no experience in designing circuits. I have made a patch for the Nord Modular G2 demo, that's pretty much complete in design, I'll attach it in my post. The thing is, I really have no idea how I would go from translating that into a readable schematic, with component values and the like.
I'll describe it as best as I can, with words, for those who don't have the G2 demo. Okay, I still haven't decided on the final number of stages, but the module is basically several stages of VC offset summing, rectifying, fixed offset summing and amplifying. Assuming audio signals in the +-5V range (10 V peak to peak), and a +-12V PSU:
Basically you get an input signal, mix it with a CV input (LFO) and rectify it. Then you add a -5V offset to center the wave at 0v, and then amplify it with a 2x gain to retain the 10 V peak to peak. Then repeat again, with another CV input. I have been considering 8 stages of this, as more seems overkill.
Ideally, the module would have both a dedicated CV in and audio output for each stage, a couple of master audio inputs with attenuators, to facilitate feedback loops. It would be DC-coupled, in order to process LF signals too.
If anyone is willing to help me, I'd sincerely appreciate it a lot, I'll try and design the PCB afterwards, and if anyone is interested, I might do a small commercial run.
Best regards,
João Paquim
Blackened Justice
Anyone out there?
neandrewthal
I've never designed a circuit either, but here's my go at it. Hopefully it will at least be a starting point. Maybe someone who knows better can critique it. Oh yeah, the -5v should be -2.5v. You could derive that with some s[/img]ort of voltage divider circuit.
daverj
neandrewthal wrote:
Oh yeah, the -5v should be -2.5v. You could derive that with some sort of voltage divider circuit.
Or leave it -5, since that's an easy voltage regulator to get, and use 200K resistors to -5 instead of 100K to -2.5
jjclark
As I mentioned in your other thread, you can AC couple the sections instead of offsetting. This will simplify the circuitry. And I suggest that you use "precision rectifier" circuits (basically putting the diodes in the feedback of the opamps) otherwise your rectified output will not go down to zero. Diodes will have a 1/2volt (for germanium) to 0.7volt (for silicon) drop across them. Placing the diode in the feedback loop cuts the effective voltage drop by a factor equal to the opamp gain.
Just do a google search for precision opamp (fullwave) rectifiers to see the circuit.
neandrewthal
Oh, I didn't know you could have some inputs amplified and some not with the same op-amp. Then you could insert the CV in there via a 200k as well, making 3 of the 5 opamps in that part of the circuit redundant.
daverj
You might want to make it with fewer stages. Something to consider is the amount of amplification this will have, and what that will do to noise.
If there is, for example, 10mv of noise on the original signal, which is only 1/1000th of the original 10v p/p signal, so not very noticeable, by the time you get out of stage 8 that 10mv becomes 2.5 volts, or 1/4 of the total signal.
That's a lot of hiss.
neandrewthal
Yeah, and with 8 stages I could see things getting so harmonically complex that the signal itself sounds more and more like noise.
daverj
Not to mention that it would push many frequencies up beyond the range of what you can hear. A 60Hz triangle going in would be over 15KHz at the 8th stage.
Blackened Justice
You're probably right. Remember, all the testing I've done has been done with the Nord G2 demo, so real-life issues such as noise really aren't a problem there. What should I consider, then? 4 stages? Maybe a dual set of 4 stages multipliers behind a single panel?
As for AC coupling, that would be cool, but the offset amount could be of some interest to have controlled by a knob.
I'll have to do some more testing, I wish I had an oscilloscope, but for now, I'm going to have to trust my ears.
Please keep the suggestions coming, everyone. It's been really useful.
DGTom
If it were me, I'd build single, or, maybe dual stages, & just cascade them when you need to; its modular!
Blackened Justice
What about a 4 stage, or whatever, but with individual inputs for each stage, where each stage's output would be normalled to the next stage's input? It would allow for completely modular patching and still have them cascaded by default.
Blackened Justice
Okay, I've been reading up on op-amps, and now have a better idea of what you did on the circuit. However, I'm a bit confused by your comment here, could you post this simplified version you speak of? Maybe even using AC coupling instead of summing -5V DC, to simplify it further, as was suggested.
João Paquim
neandrewthal
Here is my circuit simplified by Dave's suggestion:
(the cut off resistor at the top is 100k)
I don't see how AC coupling would simplify my circuit any further, but I think what jjclark was getting at is to take this circuit:
but also run your lfo into each opamp via a 10k and 20k resistor as shown, then run it through a capcitor, lather, rinse, repeat. I have to admit I don't understand it, but if it works that way with higher performance, I'd say that's the way to go.
Blackened Justice
Thank you very much, you've been extremely helpful. AC coupling would simplify it by removing the -5V regulators and the associated 200k resistors, and just putting a capacitor in series with the pair of diodes.
I've got some questions about circuit design, in general:
1) How do you choose the resistor values when dealing with opamp circuits? I know the gain of an opamp is defined by the reason between the resistance in the feedback and the resistance at the input (when dealing with inverting amplifier configurations), but how do you actually specify said resistors at 100k and not 10k or any other value?
2) Why is there a 1k resistor on the output? Shouldn't the output inpedance be the lowest possible?
3) Before each stage of rectification, do you really have to invert and reinvert the voltages, couldn't you like invert it once and put that inverted output through the first diode, then put the original signal in parallel through the other diode? Would that make a too low impedance input? If so, then I could just as easily use an op-amp at the input in a non-inverting amplifier configuration, right? Or has it got something to do with the initial mixing of the input and CV voltages?
João Paquim
daverj
1 -op amps can use a wide range of resistor values. They can effect the input impedance, the bandwidth, the noise, the maximum voltage swing, etc... In op amps connected to external inputs the input impedance is often the deciding factor. 100K is the most common. You then select the feedback resistor based on the input resistor.
2 - in the early days the 1K was added to prevent the opamp from getting killed when you short the output to ground each time you patch a cable. Modern op amps can survive shorts. But shorting an op amp can cause a high current spike of 50-80ma in your power supply, which can get back into other modules. With the resistor there it limits that current. It also reduces problems if you happen to connect two outputs together.
3 - In his circuit the first op amp in each pair is used as a mixer. The second one is used as an inverter. The first op amp in the second and third pair also amplify the signals and level shift them.
re: AC coupling - while you can AC couple the stages, the drawback is you lose the ability to handle slow CV voltages. Also, because the duty cycle will change based on the shapes of the input signals, the cap will cause DC shifts as the duty cycles change. Adding a 5 volt regulator and resistors will only add maybe $1 to the cost, and is worth it.
You can also eliminate the 5 volt regulator and use a larger resistor to -12 volts. The advantage of the 5 volt regulator is that it isolates that voltage from the main power supply rails, so does not add power supply noise coming from other modules into your signal.
Blackened Justice
Thank you very much for your answers smile I really appreciate it.
Regarding answer 3), why not mix the signals passively, and avoid one of the op-amps?
daverj
For circuits like this you would normally use dual or quad op amps, so no extra chips are needed to have the mixer.
The diodes are already a form of passive mixer. Trying to add another passive mixer in front of that will result in attenuation of the signal because of the resistance after the diode. That will increase the noise from extra amplification to compensate for the loss.
Blackened Justice
Ok, thank you very much for everything. I'm gonna get some components, and try to breadboard a prototype ;D
I have some LM741 opamps, will those do fine for this type of thing?
daverj
They're slow. They're also bipolar, which means that using this circuit they'll drift with temperature (extra resistors would be needed to prevent that).
Better off using TL072 chips.
Blackened Justice
I have some more questions about the circuit:
1. If I want to take "tapped" outputs from the circuit, where would I take the signal from? Would I have to just repeat the ouput part of the circuit? Or mix the -5 and the CV using seperate opamps in series, and take the output from the -5 one?
2. In the output section, couldn't I mix using a non-inverting configuration, and thus avoid the last op-amp? It made sense in the original design, for both regular and inverted outputs, I think it can be avoided.
3. I might want to normalize the CV ins to +-5V sources. Can somebody point me in the direction of a simple attenuverter, or polarizer, if you will?
4. For all the +-5V I might have in the circuit, would I be better off using voltage regulators to get them, or just use a pair of resistors in a voltage divider configuration?
5. Should I use silicon, germanium or Schottky diodes?
6. How can I estimate current draw for this?
daverj
1 - The circuit as shown is a 2 stage unit. So there is only one "tap" point in the middle. Take it from the output of the third op amp
2 - You can take the final output from the 5th op amp and eliminate the last one.
3 - did you do a search of this forum? I would think there's a couple of threads with schematics for that
4 - Using a regulator for the -5 is best. You could use larger resistors and take it straight from the -12, but you'll mix in any noise and fluctuations that are in the power rails. A regulator eliminates that.
5 - I would use Schottky. Any of them would work. It might be best to add a large value resistor between where the diodes meet and -5 (or -12) to keep the diodes on at all times (maybe 100k).
The resistor value going between -5 and the input of the 3rd and 5th op amp would be very slightly different value for the different type diodes, though not by much, to compensate for the different voltage drops.
6 - just build it and measure it. The current draw is going to be very small.
Blackened Justice
But then I'd be getting the desired signal mixed with the CV In 2, which I may not want.
neandrewthal
Aww, shucks. I didn't even think of that d'oh!
You'll probably have to just duplicate the output section for each tap, but get rid of the second amp if you want.
daverj
This is what makes designing circuits so much fun. hyper
