Serge TKB Kit!
zthee
Panelhöna
Serge TKB Kit!
Post by zthee » Sat Feb 08, 2014 2:00 pm
Anyone who'd like a TKB?
I've got an OK from Serge to do the TKB as a kit!
It'll consist of 6 PCBs and a front panel. The PCBs are 1 x main board, 4 x pot boards and 1 x touch PCB. I'll probably include the MM74C150 IC as well. It's the only "hard to get" part.
Preliminary information can be found here - http://thehumancomparator.net/tkb/
Wiring has been simplified by mounting all the pots to 4 different PCBs.
I'll make kits during the spring (So this'll happen sometime in April/May I think) and sell in the shop. The price will probably be something like 3000 SEK, but I haven't checked with suppliers and stuff yet.
Text from www.serge-fans.com
Touch Keyboard Sequencer (TKB)
This little miracle is a 16 stage sequencer with 4 layers, five simultaneous outputs, sixteen capacitive touch-sensitive keys. It is a sequencer and performance keyboard rolled into one. A four-stage vertical sequencer steps through each of the four layers, allowing sequences up to 64 steps in length. The Reset input brings the sequence back to stage 1. A switch and trigger input allow the sequence to go forward or reverse, a hold input stops the sequence. A random select input randomly selects from the sixteen stages. Sequences can range from 2 to 16 steps, or multiples of 4 through 64 (8,12,16,20..) steps. The capacitive keys have a pressure output that produce a voltage proportional to the key area your finger covers. A separate KV output provides an equal-tempered voltage (16 equal steps) which is independent of the stage setting pots. A KEYBOARD switch lets you select each 4-layer stage with the keys or disconnect the key selection of the stages.
Pro: Extremely versatile. You can explore this sequencer for years and not exhaust what it's got. Can be clocked at audio rates. Easily chained to other (Serge) sequencers. The Pressure output is very nice, especially in conjunction with attenuators to make the pressure touch effects more subtle.
Con: The vertical clock doesn't reset when the Reset input goes high. If it did, it would allow more sequencing patterns. Also when 'KEYBOARD' switch is turned off, touching keys will still affect the starting stage in a running sequence, but only when you've patched one of the stage trigger outputs to the reset jack(!). Also, it needs to be externally clocked (like all the Serge sequencers I know of) so you need to use another module or external source to do this.
Wizardry: An advantage to external clocking is, you can experiment with clocking with waveforms that are not perfect pulses. The voltage range of each stage is around zero to 3.5v. When the pots are set to zero, they truly are at zero. The maxima are all different, however. Unlike some sequencers I've played with, there is no interstage interaction - turning a pot on one stage does not affect another stage.
Tweaks: The TKB design now uses bright amber LED's, which apparently are better than red ones in low-light applications. One of the Reset jacks was replaced with a toggle switch that sets forward/reverse sequencing in addition to the forward/reverse jack. The keypad material was also updated so it's more durable.
The TKB will work with Euro stuff. Banana jacks can be changed to 3,5mm jacks.
Oh, and if anyone could find a reversed version of this - http://se.mouser.com/Search/ProductDeta ... 151-2P16-E
With a flat cable inserted into this, the first line on the cable is pin 16 (counting the normal way on an IC). Due to this, the connector has to be mounted on the backside of the board, it works and I think it actually looks a bit nicer than having the cables running on top of the board. But I'm anal about things and want them the way they're "supposed to be". So I'd like the first line to be pin 1. E.g. a reversed version.
I've seen versions of the STS TKB on Flickr where the connectors are mounted topside. So it should exist. But I just can't find the correct parts... (And I have been looking...)
No PM's please! Send an e-mail - ttsh(a)thehumancomparator.net
Information regarding the Two Thousand Six Hundred DIY project - > http://www.thehumancomparator.net
_
"Oh Batman, why you got to be so heteronormative?".
Reality Checkpoint
Confused By Electricity
Post by Reality Checkpoint » Sat Feb 08, 2014 2:05 pm
Yes please! I would like one!
kollo
Post by kollo » Sat Feb 08, 2014 2:08 pm
Well, as I said on 99, ja tack!
iopop
Post by iopop » Sat Feb 08, 2014 2:09 pm
Wow! Awesome! Now I know what my sixth panel will be.
Isaiah
Post by Isaiah » Sat Feb 08, 2014 2:12 pm
Yes please! :bananaguitar:
radams
Post by radams » Sat Feb 08, 2014 2:15 pm
YES YES YES !
Isaiah
Post by Isaiah » Sat Feb 08, 2014 2:32 pm
I can't see any mention of a panel.
Does the kit include one or will there be the option to buy one?
tIB
Stainer!
Post by tIB » Sat Feb 08, 2014 2:34 pm
Its a yes from me!
Baszline
Post by Baszline » Sat Feb 08, 2014 2:39 pm
Wow! :eek:
oldenjon
Post by oldenjon » Sat Feb 08, 2014 2:40 pm
I'm in! :tu:
"We all dance by ourselves, that's why we only play electronic music"
http://synthscalledbeasts.tumblr.com/
zthee
Panelhöna
Post by zthee » Sat Feb 08, 2014 2:57 pm
Isaiah wrote:I can't see any mention of a panel.
Sorry sorry, of course there'll be a panel! I'll add it to the first post.
_
rico loverde
Post by rico loverde » Sat Feb 08, 2014 2:58 pm
damn cool.
works for Darkplace Manufacturing
consumed
International Filter Conspiracy
Post by consumed » Sat Feb 08, 2014 3:34 pm
wow, i might have to build this.
:bacon:
LetterBeacon
Post by LetterBeacon » Sat Feb 08, 2014 4:39 pm
Definitely in for one!
blinosynth
Post by blinosynth » Sat Feb 08, 2014 4:48 pm
:domodance:
richard
bananaphile
Post by richard » Sat Feb 08, 2014 4:54 pm
highly tempted
Bastard Science Vol.1 and 2 (Hordik, Buchla, Serge, EMS, Oberheim) https://soundanatomy.bandcamp.com/album ... ence-vol-1
https://soundanatomy.bandcamp.com/album ... ence-vol-2
Tales from the Voodoo Box (EMS Synthi A solos) https://soundanatomy.bandcamp.com/album ... ynthesiser
Richard Scott - Several Circles https://cuspeditions.bandcamp.com/album ... al-circles
tIB
Stainer!
Post by tIB » Sat Feb 08, 2014 5:11 pm
richard wrote:highly tempted
Would be rude not to surely!
spneca
Post by spneca » Sat Feb 08, 2014 5:42 pm
Wow!!! Yes!
xpando
Post by xpando » Sat Feb 08, 2014 5:52 pm
im in.. assuming i have the funds available when its ready. :tu:
WTB:
Bugbrand (banana) - SYN2C, CTL2, ENV1
XROM (for the XBase09)
30ohm
Post by 30ohm » Sat Feb 08, 2014 5:52 pm
Very excited to see how people hotrod this now that it's a kit!
pyramid power is real.
Reese P. Dubin
Post by Reese P. Dubin » Sat Feb 08, 2014 5:55 pm
Finally
InKrellDible
yes for me
revtor
Dialing it in..
Post by revtor » Sat Feb 08, 2014 6:02 pm
yes!
what value are the pots?
~Steve
zthee
Panelhöna
Post by zthee » Sat Feb 08, 2014 6:17 pm
All pots are 50k lin. If you don't want to wire them by hand you'll have to use 9mm pots (Like these - http://www.smallbearelec.com/servlet/Detail?no=693). 16mm pots are too big to fit unfortunately.
_
jc
Post by jc » Sat Feb 08, 2014 6:34 pm
Wow, this unexpected news...nice news though.
Microscopial
"stripes!!!" what me mmmm
Post by Microscopial » Sat Feb 08, 2014 7:00 pm
I'm in please
lamond design
"working with wood"
email/ lamonddesign@gmail.com
flickr/ http://www.flickr.com/photos/59671775@N03/
twitter/ lamonddesign http://twitter.com/#!/
facebook/ ross lamond http://www.facebook.com/ross.lamond1 or follow the lamonddesign page
website/ www.lamonddesign.co.uk
