Plan B cable -- like Doepfer?
Author Plan B cable -- like Doepfer?
MrBiggs
I just bought my first non-Doepfer modules, and before I plug these things in I want to make sure I know what I'm doing. My assumption is that the power cable should look just like the Doepfer ones do, with the red stripe along the BOTTOM at both the module and the power bus. This is correct?
thanks
sandyb
check the plan b pcbs. all the ones i have say on them beside the power connector which side the red stripe should go in big letters (well as big as you can get on a small space on a pcb help )
so red stripe goes there on the module and to the bottom on the doepfer busboard.
sandy
MrBiggs
Yep, I see that. Wow. Really glad I asked. That would have really effed my day.
Reptil
what he ^^^^ said thumbs up
the m15 has two!
https://www.muffwiggler.com/forum/viewtopic.php?t=6698&highlight=m15 ambulance
paults
If only there was some universal document format that could contain 'text', 'diagrams' and 'color photographs' to explain such things, and some method whereby 'clicking the mouse' could direct you to such a document.
