Passive Low Pass Gate - Vactrols
Moderators: Kent, lisa, luketeaford, Joe.
Hi guys,
I am trying to get my hands dirty and make some diy modules.
And maybe, learn something about electronics.
I think this would be a useful and easy one:
http://www.etsy.com/listing/180674772/p ... e_active_1
You know, we need VCAs all the time ; )
Does anyone know a good vactrol to play with it in the eurorack world at Mouser store?
... I am finishing my order and would be great to have some of this.
Thanks.
Thanks.
- Igor Berlin
- Wiggling with Experience
Well, I don't see where the Low Pass is in his LPG. What there seems to be is a voltage (current actually) controlled attenuator.
The LPG is a Filter/VCA built around a Sallen-Key filter design. I only see a few resistors and a home made LDR. This will only attenuate a signal overall, not filter it at the same time.
Also, being passive, there's no circuit controlling LED drive, that's dependent on the CV source you patch in. Also the attenuator will behave differently depending on how it's connected somewhat.
The Buchla LPG design is very nice and unique. Your not going to get the same thing from a Vactrol and a few resistors.
Nope.NS4W wrote:Have you found a description for building this lowpass gate?
Description and videos from ElectroLobotomy:
"PassiVac is a 2 HP, vactrol based, single channel voltage controlled attenuator. It requires no power! Just feed it CV. Sounds nice with minimal bleed. Makes a great passive Low Pass Gate!!"
Maybe not a LPG, I dont know, but seems like a nice VCA.CLee wrote:Well, I don't see where the Low Pass is in his LPG. What there seems to be is a voltage (current actually) controlled attenuator.
Thanks, really informative.
A couple notes:
Regarding the original question, the most commonly used vactrols in analog modulars are VTL5C3/2 and VTL5C3. Silonex vactrols like the NSL32-SR3 are also used. I don't think Mouser sells either of those. The design above uses a homemade vactrol made by putting an LED and an LDR literally in touch with one another and then covering both with heat-shrink tubing.
CLee is right -- that is not a lowpass gate, it's just a passive "VCA". While Buchla's LPGs and many other designs use a Sallen-Key filter typology, it is possible to build a very simple passive variant on a low-pass gate by just putting a capacitor to ground after the vactrol's resistor side to create a simple RC lowpass filter. See this thread (and also the Silonex datasheet) for ideas:
http://electro-music.com/forum/viewtopic.php?&t=26643
- Tim Stinchcombe
- Uncommon Wiggler
Thanks a lot, great info.Dogue wrote:A couple notes:
Maybe its the time to make some diy vactrols.
- ben_hex
- Super Deluxe Wiggler
Cheap and cheerful, is it a little kit or a pre-built thing?
All DivKid video series to be found here!
http://www.youtube.com/divkidvideo
electrolobotomy
- Learning to Wiggle
electrolobotomy
