Bananalogue VCS Ribbon cable question
Author Bananalogue VCS Ribbon cable question
Dave77
Ciao,
I wanted to ask to regard Ribbon cable of bananalogue,
the Red line connected UP in to doepfer Bus Boards?
(sorry my bad english)
Sound
Hello,
The Bananalogue VCS has labeled in its PCB -VE and +VE, You should connect the ribbon cable that the -12V of the Doepfer bus board coincide with the -VE of the module PCB.
Usually the red line is used to drive the -V.
Be careful with the VCS, if plugged reversed you will burn the LM3900 chip, since you are sending the +12V to the ground of that chip. Fix it is as easy as replace that chip.
Sound
Also the doepfer bus board is labeled.
Dave77
Ciao Sound..thanks for answer
yes the REd line connect in -VE (UP) ... for connect in Bus board doepfer a
-12V i twist cable correct ??
Sound
I guess. Whatever way just connect the -V with -V.
Regards!
Dave77
