I'm leaning towards a buy of the ADDAC703 (Reference here) but could probably do without the feedback/gate functionality and the very precise on-panel trimming.
There are quite a few CP3-ish mixers out there (manhattan analog, suit and tie guy to name two which comes to mind), but i need at least four channels.
what other options are there? The usual lower price/smaller real estate/more functionality in one module arguments apply.
CP3-style, four channel or more alternatives to ADDAC703
- Stinktier86
- Ultra Wiggler
- ablearcher
- Veteran Wiggler
- Contact:
Yeah, as I remember the channel limitations of the MA CP3 is really a panel/aesthetics/space choice. I think the original had 4, and I think all it takes to add more is a jack/pot/resistor combo. Don't know how many more you can add though, would be interesting to find out.
I see submix 7's floating around sometimes and am tempted. I have a pretty small system but it seems like I constantly need more mixing capability. I have the CP3 right now, am just about to build an MA Mix, and I'm contemplating the MVP for CV mixing/multing/attenuating.
- negativspace
- Manhattan Analog
- Contact:
The CP3 board I did has an expansion port. You can sum as many extra channels as you want into the bus, you'll need a jack + input pot + flying input resistor for each one. I just did one with 4 channels as part of this panel, worked perfectly:
From there the only limitation is how much panel space you want to devote to the job, and how much finger room you need.
