[IN STOCK] Eurorack: Discrete State-Variable VCF v1.4
M-Circus
Post by M-Circus » Thu Apr 17, 2014 11:04 am
Don't even own a case at the moment, but what the hell:
One set of PCBs and panel for me, pretty please.
sgnelson
Post by sgnelson » Thu Apr 17, 2014 11:11 am
I'll take 1 set of PCB's and a Panel please.
Mindarp
Post by Mindarp » Thu Apr 17, 2014 11:22 am
I would like 2 complete sets please, including panels. Cheers very much.
Belief is the death of reason.
Stinktier86
Post by Stinktier86 » Thu Apr 17, 2014 11:39 am
what is the estimate bom sum price? just checking whether to go nuts or not. :love:
ablearcher
Post by ablearcher » Thu Apr 17, 2014 12:06 pm
1 set (panel + pcb) here please!
hsimonis
Post by hsimonis » Thu Apr 17, 2014 2:48 pm
Two complete sets (PCBs plus panels) please!
KNYST
hiding in the forest
Post by KNYST » Thu Apr 17, 2014 4:41 pm
YES! :party:
2x PCB sets + panels
[edited/updated amount]
NOISE HEALS.
patch responsibly.
LISTEN | WATCH
sicpaul
Post by sicpaul » Thu Apr 17, 2014 6:10 pm
2 PCB sets please (no panel)
negativspace
Manhattan Analog
Post by negativspace » Thu Apr 17, 2014 6:29 pm
Holycrapsixpages... I'll work on compiling the orderlist tonight so I don't get too far behind. :eek:
Those of you not interested in a panel, please be aware that this thing is not a multi-format PCB like I usually offer. It's made to integrate with the Euro panel and one of the PCBs has no other purpose than to hold the panel controls. So you'll only need the one board if you're working in a non-Euro format. (Bonus for you.)
If you want a control board with which to do your own panel using the same control layout I'll send you a blank FPE file with only the hole locations so you can roll your own. :tu:
You can still build it in other formats, there are mounting holes for standoffs, but you'll need to solve the power on your own (Euro header only) and you'll also have to wire it up using the pads for the inter-board headers. It's not a big deal, it'll work perfectly, but I wanted you all to know what's what. Those pads are not marked on the PCB but I'll trace 'em out and make a JPG for this thread once the final layout is verified.
negativspace
Manhattan Analog
Post by negativspace » Thu Apr 17, 2014 6:39 pm
latigid on wrote:What are the hard-to-get components?
There are none. It's all discrete. I couldn't justify $6 for 4 transistors - x4 per board - when 2N390x at $0.02/ea work and sound just as nice. As far as matching goes, I've built them with matched and unmatched transistors and couldn't really tell any difference. I recommend loosely matching them as a matter of best practice but it's not something you should worry about. (And certainly not something worth spending an extra $23 per module on.)
I even found that I liked it better with TL072s as the output buffers vs. expensive audio opamps, so I wouldn't even recommend reaching on those.
The only "specal" parts I use are the styrene timing caps (Mouser) and the particular transistors I prefer. (PN100/PN5138) The design works well with 2N390x as I said above, though, and should work with any general-purpose small signal transistors. The PCB has the pinouts marked for all transistors (EBC) so substituting your own, no matter the pinout, should be straightforward.
negativspace
Manhattan Analog
Post by negativspace » Thu Apr 17, 2014 6:41 pm
sduck wrote: Now this is my kind of BOM!
Talk about something for nothing... :hihi:
I'm hesitant to post the final BOM as I still have a tweak or two to make to the design. Once it's nailed down I'll post it. (It's probably not going to change from where it is now, I'm just being pedantic. There's only a resistor value or two left to play with.)
magneticstripper
Post by magneticstripper » Thu Apr 17, 2014 7:22 pm
I would love 1 full set please
Phetus
Post by Phetus » Thu Apr 17, 2014 9:33 pm
:goo: :sb: :goo: :sb: :goo:
I ffull set for me please!!! How do I add myself to the list?
Phetus
Post by Phetus » Thu Apr 17, 2014 9:35 pm
is this actually the paypal address? xxxxxxxx@gmail.com
Cat-A-Tonic
Lobsters love Muff
Post by Cat-A-Tonic » Fri Apr 18, 2014 1:39 am
The demo sounds fantastic!
I don't really feel like I need more filters in my backlog at the moment, but... you make it hard to resist.
Nice job. :tu:
nigel
Post by nigel » Fri Apr 18, 2014 1:39 am
This one has been on my list for a while. 1 panel + PCB set.
Rigo
Post by Rigo » Fri Apr 18, 2014 1:52 am
Phetus wrote::goo: :sb: :goo: :sb: :goo:
You just did ...
Phetus wrote:is this actually the paypal address? xxxxxxxx@gmail.com
No ... since the exact price isn't known yet there is no need for putting the correct address. Though you could easily find it out by looking at any of the other order threads from Negativspace :hihi:
latigid on
Post by latigid on » Fri Apr 18, 2014 5:43 am
Cool, 2x 1 nF polystyrenes? I'm contemplating an order from musikding.
nikmis
my last name backwards
Post by nikmis » Fri Apr 18, 2014 7:19 am
negativspace wrote: Those of you not interested in a panel, please be aware that this thing is not a multi-format PCB like I usually offer. It's made to integrate with the Euro panel and one of the PCBs has no other purpose than to hold the panel controls. So you'll only need the one board if you're working in a non-Euro format. (Bonus for you.)
Thanks! so two of those main circuit PCBs for me
windspirit
Post by windspirit » Fri Apr 18, 2014 7:36 am
im in for a full set. this thing sounds really smooth
4285407da1d2a63820a3007c1
Post by 4285407da1d2a63820a3007c1 » Fri Apr 18, 2014 7:46 am
One full set for me, sounds great!
Delta T
Post by Delta T » Fri Apr 18, 2014 8:13 am
I'll take two complete PCB sets (no front panels) and when you have a chance I would like a copy of the FPE layout as well.
Thank you so much for doing this!
Stinktier86
Post by Stinktier86 » Fri Apr 18, 2014 8:15 am
negativspace, regarding what you wrote in this thread viewtopic.php?t=110487
and since the CP3 circuit is essentialy the same - would i be able to add a couple of more channel ins to this one too, and thereby hit two birds with a rock?
bonus question: would i be able to tap the mixed signal, pre-filter, to a separate extra output jack?
Skaput
Post by Skaput » Fri Apr 18, 2014 10:44 am
:party: iam not missing this party, 1 set for me please
duff
Post by duff » Fri Apr 18, 2014 11:11 am
I'm interested in a full set, and possibly some single boards as well.
