Author |
Buchla 200e with TipTop audio banana cables |
br>amnesia |
br>just wondering if anyone has tried the Buchla 200e with TipTop audio banana cables? br> br> |
br>cbm |
br>neandrewthal |
br>
Why for, señor? br> br> |
br>cbm |
br>At the risk of being a broken record, the 3.5 mm jacks and plugs that are used in most equipment today are not really compatible with the .141" Tiny-Jax that were used on ARP and most equipment from the 1960 and 1970s, as well as on past and present Buchla equipment. br> br> |
br>amnesia |
br>infinite7 |
br>
agreed, it's disappointing that buchla doesn't play well with others. br> br> |
br>gaslampmusehog |
br>I understand the size difference and all that, however if you download the stackcable manual it reads, will work well with tinyjax jacks, but obviously not well with tinyjax plugs. br> br> |
br>cbm |
br> infinite7 wrote: | agreed, it's disappointing that buchla doesn't play well with others. |
Well, given that Buchla is making modules that still interoperate with modules that were made in the 1960s and 1970s, I can't fault the decision to maintain compatibility, and to stick with what works. The open-frame Switchcraft .141" Tini-Jax are really dependable, the Switchcraft cables that Buchla uses are the best I've used. These standards were established before there were any synthesizers that used 3.5 mm jacks.
Other synths that use the .141" jacks/plugs include:
ARP
Salamander (SMS)
Octave
Aries
and pretty much any US synth that didn't use 1/4" jacks or bananas from before the great analog extinction of the 1980s. br> br> |
br>cbm |
br> gaslampmusehog wrote: | I understand the size difference and all that, however if you download the stackcable manual it reads, will work well with tinyjax jacks, but obviously not well with tinyjax plugs. |
I wonder about that assertion. My experience using 3.5 mm plugs on the Buchla is that it kind of works, but if you jiggle them they will often break connection while wiggling.
I think that some percentage of people who complain about the jacks on a 2600 are probably trying to use it with 3.5 mm patch cords and find that the jacks are "loose." br> br> |
br>gaslampmusehog |
br>For the record, I agree with you cbm, And feel it is a bit misleeding. br> br> |
