PowerOne Supply
whomper
PowerOne Supply
Post by whomper » Thu Jul 03, 2008 2:59 pm
Hi,
I have 1 Blacet power supply and as I have started to assemble more components, I am looking out for a bigger power supply to connect all parts which are not sound producing.
I picked up a PowerOne HBB15-1.5A and am looking out for some guidance on how to hook it up.
Does anyone have some insights?
consumed
International Filter Conspiracy
Post by consumed » Thu Jul 03, 2008 3:08 pm
you should have a diagram on the psu itself on what to connect to configure it for 12v or 15v. make sure you heatshrink those exposed metal connections. you might also have to calibrate its output using a DMM.
i have to go down this road with my modular as well, but ive been putting it off.
krisp14u
Oakley4All!
Post by krisp14u » Thu Jul 03, 2008 11:38 pm
I have 2, 1.5A PowerOne supply’s setup and running fine and I’ve got a monster 3A one to install in a new case
This is a guide on how Fonik has his PowerOne supply set up it may help
Just go through the photos and use the manual you got with your supply
http://www.modular.fonik.de/Page24.html
Take your time and take care mains Power is no fun when it’s running through your body
consumed wrote: make sure you heatshrink those exposed metal connections
Don’t skip this stage and if you can’t get heat shrink to go round all of the connector you can use a blob of silicone sealant let it dry over night before you use the power supply
Paul
consumed
Post by consumed » Fri Jul 04, 2008 1:13 am
never saw fonik's site before! thanks for posting that paul.
Kwote
Voltage Controlled Crackpot
Post by Kwote » Fri Jul 04, 2008 1:25 am
sorta related but on Blacet's Bargain Basement page there selling PS PCB's
http://blacet.com/bargains.html
http://blacet.com/PS500sch.pdf
i'm wondering what it would take to safely build this up and what it would cost. perhaps i'll start a new thread if necessary, but i think it'd be cool to band together and see about cheaper power alternatives for all the formats.
edit- it looks like it can be built to produce 1000ma based on the PCB silkscreen
kwotemusic.com
my other sites
wait, what?
Post by Muff Wiggler » Fri Jul 04, 2008 1:28 am
i've always been curious about the '500/1000' designation on the PCB silkscreening of those. I wonder if they can be built up to provide 1amp.
Kwote
Post by Kwote » Fri Jul 04, 2008 1:32 am
Muff Wiggler wrote:i've always been curious about the '500/1000' designation on the PCB silkscreening of those. I wonder if they can be built up to provide 1amp.
i don't see why not. if only there was a diy manual :help:
kwotemusic.com
my other sites
whomper
Post by whomper » Fri Jul 04, 2008 6:54 am
I connected the power one power supply today according to the diagram, added a 0.75 Fuse before as required, powered it up and all's well!
I am using the Blacet power distributers. In each cabinet I place one and chain them together and into the power one supply.
I picked up the power one for roughly $65, so one does not mind the hassle and excitement of playing with wall outlet voltage, it a great bargain.
