Eurorack GPS tracker
Bobby
Post by Bobby » Sun Jun 01, 2014 3:15 pm
dont suppose anyones made one of these? (cos I'm paranoid)
...would obviously need rechargeable batteries off the rail.
thiagozt
Post by thiagozt » Sun Jun 01, 2014 4:19 pm
I've been thinking a lot about this lately...
soundcloud.com/PartialObjects
CF3
Post by CF3 » Sun Jun 01, 2014 4:36 pm
Post by JohnLRice » Sun Jun 01, 2014 4:49 pm
I keep thinking that it should be possible to hookup a cheap mobile phone that is GPS enabled inside a modular case. It would charge off the +5v rail any time you had it on and then you could use your main smart phone, tablet or computer to track it down.
ether
Post by ether » Sun Jun 01, 2014 6:30 pm
I'm considering some kind of "Kensington lock" connector for my portable case.
Post by JohnLRice » Sun Jun 01, 2014 6:44 pm
Someone should make a security module with the GPS tracker, a Kensington lock opening and indelible ink dye that shoots out the jack holes if the correct code isn't entered. :hihi:
Dcramer
Post by Dcramer » Sun Jun 01, 2014 7:06 pm
Build an old iPhone into your case in a hidden spot with power.
Activate tracking when needed.
:party:
Kingnimrod
Post by Kingnimrod » Sun Jun 01, 2014 9:12 pm
I have thought about this as well. I wonder if all the modular stuff would interfere with GPS.
celestial tomes
Post by celestial tomes » Sun Jun 01, 2014 9:14 pm
let's keep this goin. it means a lot for the travelers. somebody make this
no-fi
Post by no-fi » Sun Jun 01, 2014 10:20 pm
GPS doesn't work well at all indoors. so yeah, a smartphone with network assist and wifi location ID is probably your best bet for doing this.
You'd want a special 5V adapter to charge it. I'd be most worried about cell network transactions screwing up your audio when you were actually using the synth.
nathanxl
Pickup Truck Full of Forty Minutes
Post by nathanxl » Sun Jun 01, 2014 11:09 pm
no-fi wrote:...I'd be most worried about cell network transactions screwing up your audio when you were actually using the synth.
You could have it come on when the modular is turned off and visavis...
Adamalthus
Wiggling with Entangled States
Post by Adamalthus » Sun Jun 01, 2014 11:27 pm
Seems like this product would fit most of the requirements. http://www.globaltrackinggroup.com/gps- ... oducts.cfm including hibernating when at rest, activation over the air - so trackable when needed - low voltage charging etc.
kao:be.
Post by kao:be. » Mon Jun 02, 2014 2:57 am
need some DYI to put into the rack, but worth a check I think:
http://www.integratedtrackers.com/GPSTrack/Products.jsp
Joe.
Wired for sound
Post by Joe. » Mon Jun 02, 2014 3:31 am
Pop an RC Plane 'UHF beacon' in your case?
They're super cheap, and searching for things using a Yagi looks cool.
kao:be.
Post by kao:be. » Mon Jun 02, 2014 9:36 am
kao:be. wrote:need some DYI to put into the rack, but worth a check I think:
I have some more time, so I drop a few more details here:
this device is equipped with GPS and a sim card (so it works indoors, and it sends cell information via sms in case the GPS can't connect to a any satellite)
it is also equipped with a movement sensor, so if someone lifts or moves your device it sends an sms. this feature can be switched off.
version 2 of the device is in the pipeline and it will also support GLONASS which is the Russian alternative of the GPS.
Both GPS and GLONASS has some advantages over the other, so it is good to have both.
also in version 2: I have no idea how you call it in english, but in version two the device will be equipped with a "radio-locator" or "radio direction finder".
So once you have located your stolen device with e.g. GPS and it has led you to a huge apartment building with 50 apartments, you can use the radio device to get closer and closer to your device by checking the strength and the direction of the radio signal, and locate the exact floor/apartment where you can find your stolen stuff.
a smartphone app is also going to be implemented if I'M correct
BTW i'm not working for integrated trackers :D I just read about this product on the net earlier, so don't take any of the "to be released" features as a fact.
it worth checking I think. the spy-lamp looks very easy to build into a synth-case.
Bobby
Post by Bobby » Mon Jun 02, 2014 11:37 am
@Kao:be that is very interesting. The fact it has a USB charger could be good. Anyone know of a eurorack to USB converter?
FetidEye
demonic space drone
Post by FetidEye » Mon Jun 02, 2014 1:41 pm
the first thing i thought about:
GPS data is pretty useless for modulations unless you drive around with your modular case. Then it might be something like a very slow(?) LFO
bkbirge
Post by bkbirge » Mon Jun 02, 2014 2:29 pm
Bobby wrote:@Kao:be that is very interesting. The fact it has a USB charger could be good. Anyone know of a eurorack to USB converter?
Synthwerks lamp modules would work for this.
Modular & Dork Rock:
https://bkbirge.bandcamp.com/
Racks:
https://www.modulargrid.net/e/racks/view/88730
https://www.modulargrid.net/e/racks/view/89177
https://www.modulargrid.net/e/racks/view/379579
"The person who says it cannot be done should not interrupt the person doing it." ~ Puck, 1903
Bogus
Post by Bogus » Mon Jun 02, 2014 2:50 pm
How about a module that fires poison darts if someone without the right fingerprint flips the power on?
zoogoo
Post by zoogoo » Sun Apr 15, 2018 8:45 am
Don't they make a relatively cheap scanner that can find any cellphone, lojak or and GPS tracker? They could drive the module to a random location and rip it out. Maybe there is a scanner scrambler that can also be installed?
AW198
Pickle Tickler
Post by AW198 » Sun Apr 15, 2018 3:46 pm
zoogoo wrote:Don't they make a relatively cheap scanner that can find any cellphone, lojak or and GPS tracker? They could drive the module to a random location and rip it out. Maybe there is a scanner scrambler that can also be installed?
Dude how expensive is your modular if you're thinking it through this far
mattsb
Post by mattsb » Sun Apr 15, 2018 4:29 pm
At a much more reasonable price point, https://www.thetileapp.com
It's passive-ish, relies on a broad community of other people who run the Tile app for tracking, cheap, and easy to hide in your case behind the busboard.
johny_gtr
Post by johny_gtr » Sun Apr 15, 2018 4:45 pm
it will be more interesting to have engraved s/n on each module with open/MW database. Cars with many with s/n are not so interesting for thieves like car with unnumbered parts.
On live performances you just need a friend or two who can look at your stuff when you need to talk with some guys. Every musician has an experience of lost item on the gig
modular percussion and scapes - http://ovod.bandcamp.com
mu modular space electronica https://7k-ok.bandcamp.com
zoogoo
Post by zoogoo » Sun Apr 15, 2018 8:41 pm
maybe around 4 so far
zoogoo
Post by zoogoo » Sun Apr 15, 2018 8:45 pm
Bogus wrote:How about a module that fires poison darts if someone without the right fingerprint flips the power on?
i was thinking of something that gases them, then you can draw a bunch of penis's on their face with sharpy before cops show up.
