Motu Volta and the 200e
Author Motu Volta and the 200e
Oxix52
I bought Volta some time ago with the plan of using it with my new 200e modules. I have the 1/4" TRS to banana cables for interfacing, but I'm not sure if I need to run a ground. I had read somewhere that you needed to send the tip to the banana and the ring to ground. Anyone have any info?
cbm
You really only need one ground. I would figure out a way to get the sleeve of one of the jacks to the grounding banana on the back of the middle boat.
Oxix52
Ok, that sounds good. I wasn't sure what that banana on the back was for. Is it specifically for ground something else?
Thanks for the info.
cbm
That jack is for grounding systems together.
