Author |
STG Graphic Sequencer don't run |
br>Andreus |
br>Hi,
Sorry for my stupid question,I'm just get STG Graphic Sequencer and I'm connected, but him doesn't run. What I do wrong? br> br> |
br>Umcorps |
br>Andreus |
br>Yes, I have 5v adapter from make noise or I need another? br> br> |
br>suitandtieguy |
br>are any of the stage LEDs lit? br> br> |
br>Andreus |
br>Hi,
Yes, the first br> br> |
br>suitandtieguy |
br>where did you get it? br> br> |
br>Andreus |
br>In analoguehaven, but before 2 years ago, just connected the module now. br> br> |
br>mikecameron |
br>This might be a stupid question, but is your Sequence length set to something higher than 1?
Also, What are you triggering it from? for 99% of modules triggering is totally normal, but i've seen some things need to have the trigger buffered by patching through an active mult for it to trigger properly. br> br> |
br>Andreus |
br>Hi,
Yes,my sequence set to 8, but leds lit on 1.
Thanks br> br> |
br>Section956 |
br>I had the same issue. I realized I had another module on the same board plugged in backwards and I guess that can fry the Graphic Sequencer. Anyway, I'm in Chicago so reached out to STG and he fixed it for me at a local store a very reasonable cost. Props to STG for great service! br> br> |
br>PolarIceCaves |
br> Section956 wrote: | I had the same issue. I realized I had another module on the same board plugged in backwards and I guess that can fry the Graphic Sequencer. Anyway, I'm in Chicago so reached out to STG and he fixed it for me at a local store a very reasonable cost. Props to STG for great service! |
I seem to have the same problem as the OP
Tried to contact STG but received no reply
Could someone recommend a place to get this fixed?
thanks
EDIT: STG got in touch and sorted this out for a small fee. thanks STG! br> br> |
br>DieizzyeiD |
br>I just bought a STG Graphic Sequencer theough Reverb and the seller told me he had plugged in direct to his Mantis. I also own a Mantis so I tried it myself but no lights come on. Do i require an adapter for the Mantis or for my Intellijel 7u? Any help would be very helpful. I cant seem to find any manual online so all advice is welcomed! Thank you in advance for any help provided! Keep Patching!
Update. Figured it out! Sorry for the panic! br> br> |
br>wxyz |
br> Andreus wrote: | Hi,
Sorry for my stupid question,I'm just get STG Graphic Sequencer and I'm connected, but him doesn't run. What I do wrong? |
Similar problem... If I plugin a Sto as a clock it runs, but an Oberkorn clock, RS200 clock or Tempi don't work br> br> |
br>Just me |
br>Can't speak to the euro version, but the MU requires a +5v gate (run) and clock to operate. br> br> |
br>wxyz |
br> Just me wrote: | Can't speak to the euro version, but the MU requires a +5v gate (run) and clock to operate. | Thanks for this switched to RS200 gates and all was fine. br> br> |
