SSL - Dual Noise Module
Discussion and support for Synthetic Sound Labs modules and devices.
Moderators: Kent, dslocum
dslocum
darwin's nemesis
Post by dslocum » Wed Jun 18, 2014 7:00 pm
Working on a REALLY flexible 1 MU noise module.
It will have 8 different types of noise (not yet finalized). Scratch (like records clicks & pops), standard noise, slopes, curves, glitchy, stabs, lumps, spikes, etc. There's also a separate gate output.
Did I mention that there is an audio and LF mode as well as a "frequency" control and external frequency CV input.
OH, and did I mention that the are TWO of these in 1 MU?
This thing is worth it's salt.
Doug Slocum
www.steamsynth.com
"I guess all the Forest Mims Radio Shack books I read finally paid off!"
"I ordered twice as many _______ as I thought I'd need, only to find out that I'm still less than half way to having enough."
"...this whole thing was started by a dream and a mouse." - Walt Disney
"Flatulence sounds aren't just for brass and reed instruments anymore, thanks in large part to Dr Moog." - Ockeghem
sonicwarrior
Re: SSL - Dual Noise Module
Post by sonicwarrior » Thu Jun 19, 2014 3:43 am
Is it digital noise or analog? Frequency control sounds like digital. But digital noise should have a random output (maybe the gate output?).
Soundcloud
For sale: Jürgen Haible Tau Phaser (MOTM format)
whitewulfe
Chaos beckons, I heed the call
Post by whitewulfe » Sun Jul 20, 2014 2:20 pm
Oooooh, sounds quite lovely!
Bryan B
Post by Bryan B » Mon Jul 21, 2014 4:18 pm
Sounds tasty!
doctorvague wrote:I like hiding out at Muff's. Let's build a fort out of some chair cushions and a blanket.
JP wrote:Hell I want to be able to turn my toaster on with a CV trigger.
dslocum
darwin's nemesis
Post by dslocum » Thu Jul 31, 2014 4:14 pm
To get all the flexibility (oh yes, it has that!) the noise is produced with a CPU, but the output is 10 bit analog. There's also a range switch, so you can use it as a really cool low frequency source.
And yes, it has a gate output in addition to the analog output.
Two voltage controlled, 8 waveform noise sources in 1 MU is the goal. Prototype boards are in house - I just need time to populate them and test the software.
And in total respect for Mr. Buchla and those other West Coast folks. it's named: "Twice Maybe".
I'll put up a panel design shortly, but would like to raise enough $$$ to get this into production, sooner than later.
Doug Slocum
www.steamsynth.com
ualslosar
Post by ualslosar » Tue Oct 14, 2014 8:37 pm
Hi Doug,
Put me down for "1", please. Never enough noise...
Larry
cornutt
Fig juggler
Post by cornutt » Tue Oct 21, 2014 2:54 pm
I'm in for one.
Sequence 15 -- sequence15.blogspot.com
tehfizzle
Post by tehfizzle » Mon Dec 08, 2014 8:51 pm
I don't know how I missed this earlier, but I'd like one too.
jl
Post by jl » Fri Jan 02, 2015 2:40 pm
Wish I had found this thread sooner.
I'm pretty interested. While I have standard noise covered, I'm definitely interested in something that can produce the sort of random scratches, pops clicks, you might get out of something like a cracklebox or a hexe melusine pedal.
Would be nice to have some sort of sync between the two sections, eg have one default routed to the other if its in low freq mode with an empty out jack, but I'd rather this come out sooner and have less feature creep.
Psyched about the possibility of pairing this with a JJPSamplecorder, which will never happen since you aren't making any more :doh:
Vacancy Of Disco
Post by Vacancy Of Disco » Tue Feb 24, 2015 9:33 pm
Sounds like it's will pretty great! Almost like a skinny west coast random source (sorry I'm sure builders don't like their modules compared to other modules)
alternating.bit
Post by alternating.bit » Fri Apr 10, 2015 6:35 am
Want.
Return to “Synthetic Sound Labs”
