Euro-Duino by Circuit Abbey
evs
Post by evs » Wed Jul 09, 2014 11:03 am
just saw this at modulargrid..
even with a price, so it can not be too far away..
http://www.modulargrid.net/e/circuit-abbey-euro-duino
but i did not found any talking about this yet, no other information...
so, who wants to share some information? :party:
evs
Post by evs » Wed Jul 09, 2014 11:42 am
allright... didn´t find that in the first place..:
viewtopic.php?t=117066&highlight=euroduino
however, looks nice enough that this module can his their own thread..!
Kodama
Post by Kodama » Wed Jul 09, 2014 2:15 pm
Nice price. I'm building one at the moment. :guinness:
evs
Post by evs » Wed Jul 09, 2014 3:36 pm
where...? but its not even yet availible on their site.. or do you work for them? :banana:
BrotherTheo
Post by BrotherTheo » Wed Jul 09, 2014 3:59 pm
Okay, here goes: The announcement video is here
The Euro-Duino is a generic Arduino based Eurorack kit in 6HP. It uses an Arduino Pro Mini 328 at 16 MHz.
Features:
2 CV inputs
2 CV output
2 Digital inputs
2 Digital outputs
2 Pots
2 3-position toggle switches
Uses regular Arduino IDE for programming and downloading
6HP, 47mm Deep
Web page is up, although a work in progress:
http://www.circuitabbey.com/EuroDuinoKit.html
Price is $95 for the kit and $145 assembled. The download cable is $18.
Available in the next few days.
--Brother Theo
Human, all too human...
BrotherTheo
Post by BrotherTheo » Wed Jul 09, 2014 4:00 pm
evs wrote:where...? but its not even yet availible on their site.. or do you work for them? :banana:
He is the Overlord. And one of our beta testers. And my marketing guy, although he does not drink martinis.
--BT
evs
Post by evs » Thu Jul 10, 2014 12:43 am
So, i'm not at all familiar with arduino... How does it work?
Is there a usb connect on the mdule to load new functions?
Could one use the same arduino "scripts"(?) that are availnle for the ardcore?
Or do the user have to do all the programming?
And which things will you offer for direct use?
Awesome price, by the way, and very interesting module..!
flx
Post by flx » Thu Jul 10, 2014 1:55 am
Interesting! But how much voltage does it accept and put out?
I once made a distortion effect with an Arduino, using just one or two lines of code :razz:
The Arduino programming language is quite easy to learn and you can also just send other people's code to the chip, using the USB cable. There are differences between Arduinos though, so I wouldn't assume that the Ardcore programs are compatible without somewhat or a rewrite.
You can also find and contact me here:
tuesdaynightmachines@gmail.com
YouTube
Instagram
nightmachines.tv
Nantonos
Post by Nantonos » Thu Jul 10, 2014 2:20 am
evs wrote:So, i'm not at all familiar with arduino... How does it work?
An Arduino is a microcontroller board that uses the Arduino name, logo and programming environment in return for giving the Arduino organization 5% of sales. Low end ones use an 8-bit AVR processor, higher end ones use an ARM M3 or M4 16-bit processor.
This particular one is the Arduino Pro Mini 328 which is very low cost. Sparkfun make it, and sell it for USD 9.95. Connecting it in a modular environment means adding input protection, and output buffering (and filtering), and a front panel, jacks, pots and Euro power.
What that gets you is an Arduino-compatible raw module that you program to turn it into something useful. There is an example sketch that creates two sine LFOs.
evs wrote:Is there a usb connect on the mdule to load new functions?
No. Part of the "low cost" is that you don't program over USB; instead you connect another microcontroller, called an ISP, to upload programs. Mind you, that programmer ups the cost for a single module.
evs wrote:Could one use the same arduino "scripts"(?) that are availnle for the ardcore?
You could use or adapt programs written for other Arduino boards, but this particular module has specific pins used for the digital inputs, switches, CV ins and pots (which go to on-board 10bit ADCs), digital outs and "analog" CV outs (filtered PWM). Sketches written for other boards would likely allocate those pins differently, so you would have to adapt them.
ondes | current rack
I am afraid a firmware change will not be able to turn a rather expensive 16-bit DAC into a 16-bit ADC, and flip all those op-amps :)
BrotherTheo
Post by BrotherTheo » Thu Jul 10, 2014 2:58 am
flx wrote:Interesting! But how much voltage does it accept and put out?
All inputs and outputs are 0-5 volts. Downloading is accomplished using a USB download cable, which is available through Circuit Abbey or Spark Fun.
--Brother Theo
evs
Post by evs » Thu Jul 10, 2014 4:20 am
BrotherTheo wrote: Downloading is accomplished using a USB download cable, which is available through Circuit Abbey or Spark Fun.
--Brother Theo
Nantonos wrote:No. Part of the "low cost" is that you don't program over USB; instead you connect another microcontroller, called an ISP, to upload programs. Mind you, that programmer ups the cost for a single module.
so... not programming with usb, but downloading? :hmm:
i´m not getting it, sorry! :deadbanana:
Post by os » Thu Jul 10, 2014 5:41 am
It's a good summer for small hackable modules with two pots!
Would be nice if Eurorack bootstraps another generation of coders. Proper coding, mind you, with an eye to resource limitations.
Funky40
Post by Funky40 » Thu Jul 10, 2014 6:23 am
he allready asked my question
For sale / reduced prices ( swiss (we are NON-EU)/ in case it makes sense_ EU/WW)(CHF +- = $):
lowered prices: Dotcom Q960: 650.- / Q119: 420 / ( i also have one or much likely two 19" Frames)
ATV A-Frame incl. Accu and Bag: 830.-, like new, quasi unused.
flx
Post by flx » Thu Jul 10, 2014 6:52 am
--Brother Theo
You program your code on the computer, then compile (build) it into a "software" and then connect the module via USB and load that software onto the Arduino chip. Sometimes you need a special USB data transfer adapter (or adapter cable) and sometimes the Arduino has a USB port itself, so you just need a simple USB cable. The Circuit Abbey module looks like it needs a special USB adapter cable, which isn't a big deal though.
YouTube
Instagram
nightmachines.tv
mckenic
pew!pew!pew!kthnxbye!
Post by mckenic » Thu Jul 10, 2014 7:12 am
Really cool and GREAT price too!
Is there ANY way (expander perhaps) to have the programming pins broken out to the front/broken out to a standard USB connection?
Imagine taking this out of your case and re-programming it 15 times to test out different code - I think I would be driven to distraction! :zombie:
Just my opinion tho and will probably end up with one anyway :hihi:
adam
Post by adam » Thu Jul 10, 2014 7:14 am
the pro mini doesn't have a usb port - the nano does though, so if it's pin compatible you could use a nano instead
that said you could always leave the cable attached and stick it out through the front of your case
boramx
lepidopteran orgasm
Post by boramx » Thu Jul 10, 2014 8:23 am
great news.
cheers bro theo!
so....
this?
https://www.sparkfun.com/products/9718
:hmm: might need to make a 2hp breakout for that header.......
euromorcego
Post by euromorcego » Thu Jul 10, 2014 8:40 am
Indeed.
From the schematics, it looks the CV out on the Euro-Duino does not have a DAC, only filtered PWM. Or am I wrong?
Hopefully some people will program some interessting stuff. The Arduino is rather limited, even more though without a DAC, but something like Euklidean rhythms or a source of randomness should for sure be possible.
Maybe with the switch, one could even put different programs into the memory, then there is less need to always upload new code. It is always good to have an extra choice of utlility modules that are only rarely needed -- for this something like the Euro-Duino would be perfect.
Nantonos
Post by Nantonos » Thu Jul 10, 2014 9:26 am
flx wrote:
--Brother Theo
The module doesn't have a USB connection, so no.
Instead you need a whole other microcontroller which does have USB, and a bunch of wires to connect In various ways - ICSP is common - to the controller that doesn't have USB.
Here is an example - the controller being programmed (the black chip) is on a breadboard, and an Arduino Uno (the blue thing) is being used to program it via the mess of coloured wires:
Here is another programmer
As a way to reduce unit costs for people making hundreds or thousands of boards that are rarely reprogrammed, its a win.
As a way to program a module that most people will have one of, and will need to program, it makes the total cost higher and the inconvenience and learning curve greater.
A board which you simply plug a USB cable into would have been a better choice here, in my opinion.
flx wrote:The Circuit Abbey module looks like it needs a special USB adapter cable, which isn't a big deal though.
$15 programmer for a $10 board. Adds up to $25 when you can get better boards (with USB) for $18 that just use an ordinary USB cable.
Nantonos
Post by Nantonos » Thu Jul 10, 2014 9:36 am
os wrote:It's a good summer for small hackable modules with two pots!
But yours has a two channel 24bit DAC, as I understand it, which is a substantial advance on just PWM (even with decent filtering, which this one seems to have).
Liquidyzer
Post by Liquidyzer » Thu Jul 10, 2014 9:43 am
This, disting and I'm sure others, the rise and rise of the multi functional programmable module? :woah:
BrotherTheo
Post by BrotherTheo » Thu Jul 10, 2014 11:40 am
Hi,
Here is how programming works: The programming cable is USB on one end and a 6-pin connector on the other that attaches to the Arduino on the back of the module. The Arduino IDE compiles the code and uploads it to the Arduino through this cable ("Upload" is their term).
My set up has a long power cable so I can have the module out of the case. I plug in the programming cable in and start developing. We looked at doing a USB connector but it would take up a lot of room. The idea of a 2HP panel with a 6-pin connector is interesting. I would have to research how to make that work. Another trick is to leave the module in the case and leave 1HP next to it for the programming cable to exit the rack.
Yes, the Sparkfun DEV-09718 cable will work just fine. We will be selling one as well.
Yes, we use filtered PWM to produce CV outputs. This is to save cost and space. The cutoff is about 200 Hz. We are looking into optionally bumping the cutoff to about 3.5 KHz. The downside is you have to diddle with timer settings, and this in turn messes with some delay functions.
--BT
Kodama
Post by Kodama » Fri Jul 11, 2014 11:28 am
It's a $95 kit, which is just crazy awesome. I have wanted a little VC clock forever, and this gives you 2 in 6hp. Of course it doesn't do everything, but for size/$/features, it is great!
You just upload programs via the usb adapter cable, which you can just hang off the side of your module.
Chances are that I will have a few setup to do special functions full time, and one to experiment with. For $95, you can afford to do that! :banana:
Kodama
Post by Kodama » Fri Jul 11, 2014 11:29 am
BTW - Brother Theo is working on getting started guides so that you can easily upload existing code, even if you are not a programmer.
bendedavis
Post by bendedavis » Fri Jul 11, 2014 12:09 pm
BrotherTheo wrote:Hi,
--BT
You should check out the Microchip MCP4728, extremely cheap and provides 4 buffered 12-bit outputs.
