what will you do with your Wave Splicer?
Chuck E. Jesus
holier than thou
Post by Chuck E. Jesus » Wed Jul 09, 2008 5:51 pm
thinking about placing a pre-order and looking for feedback...
the new Plan B Wave Splicer seems like a no-brainer perhaps, but i'm curious what you guys plan on doing with it (those buying them of course)...
spbaker
Post by spbaker » Wed Jul 09, 2008 6:31 pm
i was really torn about getting this module- but i figured with the AFG on its way i would have enough crazy waveforms to keep me happy for years, but now i think about it, it would enable me to turn any or all of my modulation sources into strange things.... i'm down for the ADSR & Headphone preamp (both necessities before the wavesplicer)- what would i do if i had one- well i'm sure it would play nice with my new ChaQuO- mixing a PWM square wave with the Chaotic output :eek: reaaalll sloooww
it would be a real flexible addition to any set up!
new DVD out now Fracture
things to listen to and look at:
http://abreojos.net
sgnhh
Post by sgnhh » Wed Jul 09, 2008 7:04 pm
The main application seems obvious, but I think it'd be cool to combine two Wave Splicers and chain them together.
REwire
Post by REwire » Wed Jul 09, 2008 7:18 pm
The Wave Splicer is my most anticipated module to come along with the AFG. The sounds I made were cool and downright nasty at NAMM when I played with it. I asked Peter what would happen if you mixed a human voice or drum loop with an Osc and he said it would just stutter between the two sources. The results are the best when you put an LFO into the spice point CV in when two waveforms are being spliced. The sound was not far off from the AFG when it's doing it's complex animated output thing.
Chuck E. Jesus
holier than thou
Post by Chuck E. Jesus » Wed Jul 09, 2008 7:28 pm
REwire wrote:The Wave Splicer is my most anticipated module to come along with the AFG. The sounds I made were cool and downright nasty at NAMM when I played with it. I asked Peter what would happen if you mixed a human voice or drum loop with an Osc and he said it would just stutter between the two sources. The results are the best when you put an LFO into the spice point CV in when two waveforms are being spliced. The sound was not far off from the AFG when it's doing it's complex animated output thing.
sounds what like what i was hoping for...i called Noisebug, they ain't making too many ELFs up front...hopefully i'm in the first run...i've figured one needs to jump on the mods when they are available...
felix
Loves the manuals!
Post by felix » Wed Jul 09, 2008 8:33 pm
While not totally the same thing, I had been achieving a similar effect with a Doepfer A-150 VC Switch and an OSC that can output a square wave and other waveforms simultaneously (in my case, the M15).
You use the square wave as the control voltage for the switch, and patch the two waveforms that you want to "splice" into the two inputs, and then take the output.
It will switch between the two waveforms at the rate of the square wave. So in the case of using the square wave (control) and other wave forms from the same oscillator (assuming they are phase aligned) you achieve the same result as the wave splicer since they are switching at their zero crossings.
Now, if you like the nastier sound, use a square wave from a different oscillator for the CV of the switch. This means that the two waveforms will not "splice"at their zero crossings and it sounds particularly nasty.
I can't take credit for this idea, it's right from the Doepfer manual for the A-150. (Well...using a different rate square wave for the CV of the switch was mine).
I would imagine that the Plan B Wave Splicer would definitely sound much better when "splicing" waveforms at a much slower rate, where splicing at a zero crossing would make the change sound seamless...like if you were splicing two different LFOs or something. Doing this with the A-150 is very "choppy".
D/A A/D
glorious dissonance
Post by D/A A/D » Wed Jul 09, 2008 10:01 pm
I am stoked for this mod... I can't wait to see what happens when you input 2 different frequency osc's!!!
Chuck E. Jesus
holier than thou
Post by Chuck E. Jesus » Thu Jul 10, 2008 3:56 pm
officially ordered, also stoked :tu:
Felix: i have the A-150 as well and have tried that patch, i'm thinking the same things you are...
REwire
Post by REwire » Thu Jul 10, 2008 4:47 pm
One of the major functions of the AFG is the dual animated pulse and saw outs. You can simulate that with the A-150 (I use A-151) by feeding two synced waves (one inverted) to 1 and 2 and trigger it with one of the same pulses. For pulses, you can then PWM each one separately. Only the ASystems RS-95's have variable saws.
The problem is that the A-150 takes time to respond to it's Cv and will impart a glitch in beween each cycle and won't be as clean as the AFG nor do what the Splicer can do as it has a super clean transition point and can switch from one wave to the next or create new waveforms by switching before the first waveform has completed and that point being CV variable.
felix
Loves the manuals!
Post by felix » Fri Jul 11, 2008 12:47 am
REwire wrote:One of the major functions of the AFG is the dual animated pulse and saw outs. You can simulate that with the A-150 (I use A-151) by feeding two synced waves (one inverted) to 1 and 2 and trigger it with one of the same pulses. For pulses, you can then PWM each one separately. Only the ASystems RS-95's have variable saws.
Hmm, I'll have to give that one a whirl.
REwire wrote: The problem is that the A-150 takes time to respond to it's Cv and will impart a glitch in beween each cycle and won't be as clean as the AFG nor do what the Splicer can do as it has a super clean transition point and can switch from one wave to the next or create new waveforms by switching before the first waveform has completed and that point being CV variable.
Ah that makes sense, it always did sound a little "spikey".
