format jumbler make noise
Author format jumbler make noise
Dave77
one question for this module
..for connect Eurorack to Serge, for ground is correct connect PS2a(Power supply of serge M-odule) to format jumbler ground, or is equal connect to Obelisk ground (m-odule power distribution) to ground format jumbler?
Davide
makenoise
Either should work. Seems the Obelisk Ground would be easiest. Give that a try first. If you have grounding issues, then try using the ground on the power supply.
T
Dave77
Thanks Tony
