Mutand Drums/HiHats D shaft Potentiometers
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, hexinverter
BrianAndren
Post by BrianAndren » Mon Oct 06, 2014 7:50 pm
Has anyone found D shaft 100K logarithmic (audio taper) potentiometers? I'm not the biggest fan of the Davies knob. I would like to use some D-shaft rubberized knobs.
Here is what I've found:
10K Logarithmic:
Mouser Part #: 652-PTV09A-4015FA103
100k linear:
Mouser Part #: 652-PTV09A-4015FB104
100K Logarithmic.
The Bourns part number should be PTV09A-4015F-A104 but I haven't found a place to buy them.
vonkhades
Post by vonkhades » Mon Oct 13, 2014 4:01 pm
I on the same quest.. but since Im converting the MutantBD and MutantHihats to Bananas, I need that the pots have NUT (and washer) so I can hold the PCB with the pots and switches.
I cannot use the ones you mention, I need Panel Mount 9mm pots :S with the right footprint (Alpha, Bi Tech or Alps).
Return to “Hexinverter Electronique”
