MFOS?
Kwote
Voltage Controlled Crackpot
MFOS?
Post by Kwote » Thu Jul 17, 2008 9:23 pm
i was just looking over a few of their boards and i noticed they're consistantly +/-12V
is there a way to get around that and make em +/-15V? or not really?
kwotemusic.com
my other sites
johnnymad
turbo wiggler
Post by johnnymad » Thu Jul 17, 2008 9:42 pm
they will work on +/- 15v. most of the time, ray lists what resistor changes need to be made. all of my mfos modules are running on 15v, some with no resistor changes made at all.
haricots
Droppin' Loads
Post by haricots » Thu Jul 17, 2008 9:47 pm
I'm currently building the MFOS VCO which I purchased from Bridechamber. The MFOS site has great documentation including how to build it so that it works in a +/- 15V system. Plus Scott at Bridechamber has been a great help!
Kwote
Post by Kwote » Thu Jul 17, 2008 10:09 pm
awesome. great news. that noise cornucopia module looks effin sweet.
kwotemusic.com
my other sites
Kwote
Post by Kwote » Thu Jul 17, 2008 10:10 pm
johnnymad wrote:they will work on +/- 15v. most of the time, ray lists what resistor changes need to be made. all of my mfos modules are running on 15v, some with no resistor changes made at all.
oh yeah, which ones required no changes?
kwotemusic.com
my other sites
johnnymad
turbo wiggler
Post by johnnymad » Thu Jul 17, 2008 10:37 pm
the state variable filter, low pass filter, sample and hold, noise cornucopia, and vca work for me with no changes. the vco has a couple of changes, and the ar generator has a bunch but they're all listed on ray's site.
if you do the noise cornucopia, you should add a rotary switch to select different outputs on the 4024 ic. i found out about that mod too late but might try to squeeze one in.
Kwote
Post by Kwote » Thu Jul 17, 2008 10:49 pm
cool thanks.
kwotemusic.com
my other sites
futuresoundsystems
<3 CMOS
Post by futuresoundsystems » Fri Jul 18, 2008 3:39 am
Even if it's a strict 12V only module, you could regulate your 15V down to 12V by using a small voltage regulator such as the 78L series.
Unique designs and ideas in sound since 2005:
http://www.futuresoundsystems.co.uk
