A trig in (like the Clock in for Ardcore)q
Discussion, support, and resources for our noise making modules and kits.
Moderators: Kent, infradead, scottwilson
Alwaysnew
Post by Alwaysnew » Sat Oct 18, 2014 10:46 am
Can this be done?
I guess for the digital ins that should work?
My problem is that if I want a play-next-note-on-trig-in I always get a number of triggers, i.e. the next note goes to next and next and so on, in other words it reads a gate. But how do I treat it as a trigger in?
scottwilson
Post by scottwilson » Sat Oct 18, 2014 11:48 am
I'm working on a slave clock that will do this plus serve as a multiplier/divider, but until then you can look at the code I just committed for a trigger input for the grid controller.
https://github.com/nw2s/b/blob/b-1.1.0- ... rigger.cpp
Code: Select all
	/* Clock is rising */
	if (this->clockInput != DIGITAL_IN_NONE && !this->clockState && digitalRead(this->clockInput))
		this->clockState = t;
		/* Simulate a clock pulse */
		this->reset();
	/* Clock is falling and at least 20ms after rising */
	if &#40;this->clockInput != DIGITAL_IN_NONE && &#40;this->clockState != 0&#41; && &#40;&#40;this->clockState + 20&#41; < t&#41; && !digitalRead&#40;this->clockInput&#41;&#41;
	&#123;
		this->clockState = 0;
	&#125;
The gist is that you need to track rising and falling states.
Here's some pseudo code:
Code: Select all
Start out by setting the clockState to false in init&#40;&#41;
Every loop&#40;&#41; check digitalRead&#40;clkIn&#41;
If clkIn true AND clockState is false, then that's the rising edge.
 - On the rising edge set clockState to true
 - On the rising edge do whatever you need to do on a clock cycle
If clkIn is true and clockState is true, then it's not a rising edge or a falling edge so do nothing.
If clkIn is false and clockState is true, then it's a falling edge
 - On the falling edge reset clockState to false
Once you get that working, you can optionally add some de-bouncing in there to make sure that you only track falling edges after at least 10 or 20ms after the rising edge.
Hope that helps...
s
mckenic
pew!pew!pew!kthnxbye!
Post by mckenic » Sat Oct 18, 2014 12:32 pm
Forgive me for jumping in here...
My time plans went out the window, rolling deadlines meant I couldn't invest the time I wanted with my ::b yet.
If I could ask, I don't want to 'emulate' everything that coming out etc but would stuff like the Zularic Repetitor/Grids type clocking and trigger gen be feasible?
Sorry again!
Dave
Alwaysnew
Post by Alwaysnew » Sat Oct 18, 2014 1:22 pm
mckenic if you're looking for Grids type stuff I might have just what you need (and more) here: https://github.com/Magnus-G/nw2sFrameworkControl
mckenic
Post by mckenic » Sat Oct 18, 2014 1:31 pm
Thank you very much Alwaysnew!!!
I have an expanded Turing, Wogglebug & Grids set-up and for the past 12 months have been obsessed with crazy random rhythms! I imagine the ::b would be brilliant at this so very much appreciated!
DL'd the docs and will have a poke!
:tu:
scottwilson
Post by scottwilson » Sat Oct 18, 2014 3:18 pm
Another way to get grids-like behavior, but with customizable patterns is if you check out the probabilistic trigger sequencer ino.
It's set up so that you have a matrix of probabilities that a trigger will occur on any given beat. The probabilities are CV adjustable in real time as well.
(There may also be a monome version of this soon...)
s
Return to “nw2s”
