MODSEQ PARTIAL KITS, DIY mini roto-seq, shipping monday
Author MODSEQ PARTIAL KITS, DIY mini roto-seq, shipping monday
phono1337
EDIT 23rd OCT:
If you are on the waiting list you should have a mail today, if you didn't get the mail please check your spam folder or drop me a message so we can see what happened. As usual whats left from this batch after the waiting list is done will go to first come first served.
Meanwhile if you want to get on the waiting list for the next batch (as usual no obligation) drop me a mail on [email protected] and I'll let you know when they are ready.
and just to jog your memory
http://www.dinsync.info/2014/11/modseq-kits-are-here.html
tikami
That's certainly a comprehensive build guide you've authored there. Nice work!
mrtweed
email sent thumbs up
phono1337
thanks, really tried to make it as simple as possible, of course this makes it longer but better to have all the info thumbs up
phono1337
stabilt
The super manual with hi res photos and one step per page.
Great work!thumbs up
budinis
email sent 8_)
phono1337
we are about halfway thru the pre packed kits, so there's still time w00t
reodjectz
Ordered.
I wonder how much muff's graphics influences euro prices. Hmmmm.
phono1337
just had a quick look and there are only 20 kits left Dead Banana
ilya.n
Emailed... Would look good next to my Sara.
phono1337
If anyone stll wants one we still have a small amount left and will be putting a few more kits together this week.
w00t
jgb
Mod for audio rate clocking: https://www.muffwiggler.com/forum/viewtopic.php?t=126619
Works a charm!
phono1337
just put together 10 more kits, this is the last of them
Abraxis
You sir, are a euro hero.
mazzazza
Built the first of my 2 modseqs a few weeks ago - loving it, keep up the good work :-)
ilya.n
Looks like the output CV in the rightmost position of the pot is 4.5V, not 5V as specified in the manual. Is this OK or I made a mistake when building a kit?
Thanks.
phono1337
it should be 5v or very close to it, can you double check that there are no shorts on the potentiometer pins. If you have a magnifying glass it might be good to use that to examine them closely.
Otherwise drop me a line on [email protected] and we'll figure out whats going on here thumbs up
ilya.n
well, I can't see any obvious shorts... Just checked, it's 4.5V max on all pots.
EDIT: Problem solved, had nothing to do with the module. Turned out I had lower than 12V on the positive rail which was in turn caused by a wrong setting on a power brick.
Thanks Paul for the advice and prompt response! we're not worthy
masru
Any chance we see these kits again some time?
phono1337
more modseqs incoming wink
jgb
Incorporating the audio rate mod? smile
I have been playing with the thougt of having a step select output signal, ie eight trigger outputs. Could be used for setting sequence length or just triggers for something else.
phono1337
nothing has changed, so its still your mod wink
nice idea smile
atte
Kits? Where? Price? Amount?
phono1337
bump for the first post edit, partial kits incoming
