It requires a -10v trigger and I want to be feeding it positive triggers so I've made a board with a bunch of inverting op amp buffers like this..
This works great except that when the trigger points are connected, they no longer function when using the internal sequencer.
Does anyone know a better solution?
I was under the impression that a buffer would separate the circuits and preserve the original functionality.
The voices trigger on a falling edge of a positive pulse so you can just feed it positive triggers but I'm concerned with timing issues.
Thanks in advance for any help.
