USAMO
MUFF WIGGLER Forum Index -> Expert Sleepers Goto page Previous  1, 2, 3 ... 13, 14, 15 ... 28, 29, 30  Next [all]
Author USAMO
brackets
Hey Skaput!
Turned the monitor preset 3 on, and no luck.
I'm not recieving any audio on the analog out 3.
Very weird
I recommend not using the Mix assignments for the outputs. Use the direct DAW outputs (e.g. like DAW 9 on Line Output 9).
Skaput
brackets wrote:
Hey Skaput!
Very weird
Have a look at the output groupings in Ableton and make sure 3 and 4 are selected for mono only, uncheck the box yellow box that says stereo,
brackets
I allready had the output in ableton set to channel 3 (mono) not 3/4 stereo (and in my ableton audio preferences I have audio output 3mono 4 mono not 3/4 stereo. U mean that????
If u mean that, yes, it's not working.
Ufffffff.......so frustrated!!!!
Hope os can talk to the guys of focusrite and suggest a solution, if not i'll have to send back the unit to schneidersladen.
But thanks a lot skaput for your help!!!!!!!
Joan
Take the audio cable out of the USAMO and plug it into an input on your interface. Record the signal. Is there anything there? If not, you have a routing or software setup problem.
This from a Novation product specialist:
I feel very confident that the 18i20 will work…. It’s the same
architecture as the Saffire series.
I’m pretty sure I can see what this guy's problem is; by default in the
Scarlett Mix Control software all the outputs are set to have their level
controlled by the monitor knob. This means that it is not necessarily a
full line level signal that is coming out of the 18i20 output 3 (or
whichever he is using).
In the monitor section of the Mix Control window (the bit with all the red
buttons in his post) the relevant output needs to be coloured grey. This
means that particular output will be outputting a full line level signal
and will be disconnected from the monitor level control. This is the
desired set-up for the USAMO. In fact in his screen shot the switches for
all his outputs are set to MUTE which is entirely the reason no sound is
coming out of his output.To cycle through the monitor switch states simply
shift click the button.
So I believe if this guy shift clicks the output 3 button until it is grey
then the USAMO should receive a full level signal that can be better
attenuated on the USAMO box.
He offered to help you directly by email if need be, and will be testing this interface himself next week when he's back from a trip.
brackets
Hey!
I clicked with shift button until the output 3 in the monitor section is gray...no sound coming from USAMO. So I can certainly see this is some cryptic MixControl configuration that I don't know.
Can u tell to the Focusrite guy if he can send me a screenshot of how the settings should be...because this is very confusing.
I tried as well with the direct Daw output as u os suggested.....I don't see in what channel is sending the usamo audio output in mixcontrol.
Usamo is definetely sending audio because it shows in the metter in Ableton, but mixcontrol is not outputting it to my output channel number 3.
Skaput
brackets wrote:
Hey!
Hi Brackets, might be a long shot but try this, in mix three where your analog 3 output there is a small button above the mute and solo buttons , In your mix three this is switched off, in mine i have this switched on, switch this on so thats it lights up blue, then right click analog 3 and try the other line output on monitor output 3
sorry hard to explain but when you click that blue button your routing name will change and will not say mono any more.
When i unclick that box it my midi output starts to glitch and if i choose the line/headphone Right output instead of the line/headphone Left , midi stops altogether - worth a try
brackets
Thanks!!
Finally the soundcard it's outputting signal on the channel 3 output, and i see the volume in mix control.
But I had a screen with only green messages sending clock. My tr-8 was responding, but then nothing. Tried the test again and every 6 green lines 2 red lines. I tried adjusting the volume of the output 3 on mixcontrol while trimming on the usamo hardware, but still having few red lines. With the other options like sending midi notes, I only get red messages. I'm starting to suspect that the usb cable to my soundcard it's to long, or my usb ports of my laptop are a little bit fucked up. Or maybe downloading the last drivers of mixcontrol.
I'll test further tomorrow.
Thanks a lot in advance
brackets
Well...now doing the test again sending clock i just get this:
A start error followed by a clock evry 6 green lines, in a regular pattern.
Sending notes (random), just makes red lines.
Cheers[/img]
What sample rate is this? If 44.1, have you tried 48 or higher?
In general, you want to disable and re-enable the test after adjusting the levels, so it can sync up again. Not sure if that will help in this case.
brackets
GOT IT WORKING WITH MY CIRKLON AND ALL OF MY HARDWARE!!!
THANKS OS AND SKAPUT!!
Joan
YAY!
brackets
But i noticed It starts at bar2 in ableton. But at an inmaculate sync and grid snap perfection!!
brackets
I mean beat 2
MikkelM
I am still fighting to get this up and running on an octatrack, where I bounce the output from usamo plugin as audio.
I have tried to play a little bit with space and balance, but only midi on channel 1 gets processed correct.
Channel 2 has problems with some hanging notes and pitch.
Channel 3 doesn't get noteoffs at all.
Is anyone able to point me in a direction, to get this working?
OS, can you explain what space and balance does?
Mikkel
Just to clarify, are you recording the USAMO plug-in's output as audio clips, and then playing back those audio clips on the Octatrack? The aim being to send out MIDI clips from the Octatrack?
MikkelM
Yes the aim is to send out midiclips from the Octatrack as it have a very limited sequencer.
1. I bounce the audio from the USAMO plugin in ableton.
2. I transfer the audiofile to the Octatrack
3. Play back the audio to a single output on the Octatrack where the USAMO hardware is connected.
I am running 44.1khz 24bit as the Octatrack runs 44.1khz 24bit, so no downsampling is done.
The USAMO plugin works perfectly at 44.1Khz 24bit together with Ableton and my RME fireface.
Interesting. Are all the clip/track/etc levels in the Octatrack set to 0dB, so the output level from it is as high as possible?
Is the level enough to light the clip LED on the USAMO?
MikkelM
Yep, and as I have stated earlier. midichannel 1 works without any flaws.
Sorry, I didn't see any mention of the clip LED in your previous posts.
You're not trying to send multiple clips to the USAMO at the same time, are you?
MikkelM
One clip containing 3 channels of midi. I route 3 miditracks to one track where the USAMO-plug is inserted.
Have you tried, say, a clip containing only MIDI channel 3?
MikkelM
Ahhh! No. I will see if I can try that tonight.
Kubase
I have an issue with USAMO VST ver 1.07 in Bitwig, where it constantly sends the last message even though the transport is stopped. I have to re-add the plug-in to fix this, but invariably it will happen again.
Page 14 of 30
