barton quantizer offer- limited time
synthcube
you will be assimilated
Post by synthcube » Fri Jan 23, 2015 5:21 pm
add a cv quantizer to your frac system-
for a limited time, purchase a kit or assembled unit, and we will include the voltage regulator tuning PCB kit, used to improve the tuning quality of the quantizer. An $18 savings and improved tuning quality!
http://synthcube.com/cart/index.php?rou ... gory_id=69
monstrinho
Post by monstrinho » Wed Feb 04, 2015 4:22 pm
OK, I guess I missed this. Is the regulator board available separately? Could you point me to the original thread about this? I can't seem to find it...
Rob_C
Post by Rob_C » Sun Feb 08, 2015 11:24 pm
monstrinho wrote:OK, I guess I missed this. Is the regulator board available separately? Could you point me to the original thread about this? I can't seem to find it...
The regulator board (otherwise known as the "7805 to LM317 converter PCB") is available directly from Michael Barton at Barton Musical Circuits for $2 per PCB plus shipping.
The accuracy of the Barton simple quantizer is improved when the circuit gets exactly five volts. A fixed voltage regulator has a certain amount of tolerance, so the voltage can be plus or minus the tolerance range. The regulator board replaces the fixed voltage regulator with a variable voltage regulator and a trimmer pot to zero in on exactly five volts. Inexpensive parts and a quick build.
Return to “Fractional Rack Modules”
