Post Lawsuit Filter crosstalk problem
Discussion and support for STG Soundlabs modules of all formats.
Moderators: Kent, suitandtieguy
thaneco
Post by thaneco » Sat Feb 14, 2015 12:01 pm
Can anyone tell me how to get rid of the crosstalk/bleeding problem of the STG Post Lawsuit Filter? Thanks!
Sinamsis
Post by Sinamsis » Sat Feb 14, 2015 12:07 pm
What's the problem? I have one in eurorack and I haven't noticed anything. Then again I can be pretty clueless about these things.
lvoemachine
Post by lvoemachine » Sat Feb 14, 2015 12:32 pm
are you sure it's not being created by your power? Mine has no bleed/crosstalk but at one point i was using a just OK switching supply and I'd get crosstalk because the oscillator sound would travel along the power lines.
thaneco
Post by thaneco » Sat Feb 14, 2015 6:10 pm
No , I'm afraid its the module...It happens when cuttoff is zero and resonance is raised a bit. Please help
suitandtieguy
Hammond King
Post by suitandtieguy » Mon Feb 16, 2015 7:33 am
this has been documented and discussed here already, clip R43 and you lose the amplitude compensation but also lose the bleed.
viewtopic.php?t=28691
http://suitandtieguy.com
http://stgsoundlabs.com
http://knobcon.com
suboptimal wrote:... if it's music you want to make with your modular, STG should be in your system.
anderson303
Post by anderson303 » Thu Sep 15, 2016 5:00 pm
suitandtieguy wrote:this has been documented and discussed here already, clip R43 and you lose the amplitude compensation but also lose the bleed.
Really love this filter but I'm getting a mild buzz/noise issue. Is that hat we're talking about here? And are you saying that by taking some clippers to R43 (I have zero soldering experience) this buzz will go away?
THANKS!
anderson303
Post by anderson303 » Thu Sep 15, 2016 6:13 pm
On Further reading you said "I don't want to make this filter sound worse by making it sound better" neither do I. You can't hear the buzz in a mix and I don't want to lose any of it's character...
Return to “STG Soundlabs”
