"Mutable" PCB's, delight in the selection
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3 ... 41, 42, 43  Next [all]
Author "Mutable" PCB's, delight in the selection
adam
Feel the thrill of building cutting-edge modules!
Enjoy only buying the pcb's you want, instead of more than you need!
Enjoy soldering on some tried and tested boards!
Many boards successfully built so far!!!!!!!111!!!!
No minimum order, fast delivery when i have pcb's in stock
These pcb's are available:
Module Tester, price: £18 (available now,stocks running low)
build projects on the move, tailor made for designing and testing eurorack modules,
conveniently provides 12,-12 and 5v power to your projects as well as
cv, clock and audio test signals.
Allows you to calibrate vco's with it's built in frequency counter.
Pre-flashed chip for module tester, price: £7 (available now, only for sale with a tester pcb)
get up and running quickly without the need for an in system programmer, some people sell an unflashed atmega 644 for more than this smile
elements, price: £17 (sold out)
synthesize bagpipes to your hearts content along with many other sounds.
streams - price: £16, (available now, only 2 left!)
west coast bongo's without the bleed, dsp controlled low pass gate, compressor and more, dsp code drives a pair of super-clean, ultra fast analogue vca's 2 boards, main board and meter board.
Tides, price: £15 (available now)
the restful sound of the ocean in eurorack format, envelope/lfo/oscillator
can also be loaded with the alternate sheep firmware for wavetable baa's, amazing module, very popular.
frames,price: £15, (available now)
keyframing mixer - set up sets of levels on 4 super-clean vca's then use cv's and a big flashing knob to navigate through them, nothing else like this in eurorack.
Braids, price: £15 (available now)
a squillion and one vco models in one handy module
Clouds, price: £15 (available now)
get your microsound on! also features granular reverb
shelves, price: £15 (available now)
Sculpt your mix precisely, then animate it over time.
ideal for use as a filterbank. also includes separate LP, BP, HP filter outputs
3 band parametric eq with voltage control of many functions.
Uses 0.1 precision resistors for setting precise frequencies.
yarns, price: £15 (coming round december 15th)
extravagant midi-cv interface and digital oscillator
Grids, price: £15 (sold out)
mucho drum patterns
peaks, price: £10 - (available now, only 2 left, and i'm waiting on someone to pay for those)
Amazing array of drums and lfo's and envelopes and stuff
ripples, price: £10 - (available now)
liquidy 100% analogue filter with built in vca, tracks 1v/octave
branches, price: £8 (available now)
random gate madness - add spice to your rhythms, this pcb was
apparently designed to be an introduction to smd soldering.
Turn one random gate generator into 3 with one of these!
shades, price: £8 (available now)
mix and invert audio and cv with precision, 3 attenuverters with mixer.
Uses precision opamps for accurate cv processing
links - price: £6, (coming round
december 15th)
multiply pitch signals accurately, combine cv's.
buff mult using high spec op amp and 0.1% resistors, 2 input, 2 output
mixer, 3 into 1 mixer all in 4hp, super handy utility module
postage is £1 for 100g UK postage, or £3.60 Europe, £4.45 rest of world.
Most boards weigh about 50g with packaging, so i can often send 2 pcb's for those prices.
Smaller boards like ripples, peaks, branches and shades are even lighter.
I can send 4 of these boards for the lowest price.
Tracking, insurance etc is available too
ordering info:
please either send a pm or hit reply and tell me what you'd like smile
if you're not a member of this forum you can use this order form:
http://goo.gl/forms/tBMEfXNfB4
bom's are here:
https://docs.google.com/spreadsheets/d/1cqtogGVmOiN-dxsSQOX311SmHo0QrF pXQo7UR7lkvPU/pubhtml
you'll need to check these as some are slightly out of date:
pichenettes wrote:
BOMs
Note:
Once a product goes into production, this BOM gets loaded into my CM's system and subsequent changes happen there and are no longer put in the Google Docs file. So there might be two or three part value changes. In case there's a conflict with a part value between the Eagle file and the BOM, the Eagle file has priority.
About having a small run of boards assembled... Well, if this happens make sure that the people who get them know that they are not getting an official Mutable Instruments product so shit doesn't fly back to my face if it doesn't work or break.
Accurate bom's can be generated using eagles bom.ulp function.
the correct eagle files for these pcb's can be found here:
https://github.com/hadesbox/eurorack-with-binaries
These pcb's are not produced by Mutable instrument.
Technical support with building these designs is not available from Mutable instruments.
All designs have been rebranded in accordance with Olivier's wishes.
These boards are made at top notch factories in the USA and Germany. They have a beautiful gold/nickel plating.
you can rest easy knowing that the employees that produce these boards are well treated
and the factories they are made in take environmental protection seriously
horstronic
Awesome!
I'd like a module tester and a ripples PCB (maybe 2...).
Edit: And a braids please (hides)
So that's:
1x module tester
1x ripples
1x braids
Jack Gull
might be a silly question but.. are these equivalents to the "original" pcbs? as in taking the drawing in the github and fabricate it (so smd parts etc)
or are the boards redrawn from scratch?
(i remember reading a topic about a through hole braids)
Anyway, i'm surely in for a module tester. i don't know if thonk will ever stock them again asit's *officially* out of production, right?
adam
they'll be generated straight from Olivier's files on github - so smd's galore, get your magnifying visor on wink
the tester board is through hole though i think, i'm not sure they'll be produced again
Jack Gull
so.. one module tester it is! razz
adam
horstronic wrote:
Awesome!
ok - i'm editing the first post with prices etc - the factory don't charge much different for small or large boards, so ripples is £13, the tester is £18, but the tester board is literally 5x the size
so ripples will be much cheaper from OSH park but with a 20 unit minimum - i might have to say max 20 or 30 units as they step up in units of 10 - but i'm working it out wink
ppccdd
i would love Braids, Clouds, Tides. but i am also game for Streams, so i will buy one of those.
adam
ok, i'll add your name to the lists - i've just pm'd you about clouds, that buy is definitely happening - if the other ones are successful you can just pay a bit more money later and i'll send everything together
pokeyasd
Here's what I'm interested of:
Elements
Frames
Ripples
Shruthi FX/Digital filter
Shruthi LP2+Delay filter
Tides
adam
Elements
Frames
Ripples
Tides
do you mean Shruthi Digital XT?
ChrisR
Please add 1 X Braids to my Clouds order thumbs up
adam
thanks chris - i'll see what i can do - 8 more braids orders are needed at the moment
Neutron7
I would add elements, frames(x2), and module tester to my clouds.
gbiz
I'll take a Braids & an Elements please Adam.
adam
you're on the lists sir - strong showing for elements already - some intrepid souls here wink
timpecter
I'm in for a Module Tester
and (deep breath)
Ambika mobo with 6x SMR4 cards
pokeyasd
adam wrote:
Elements
Frames
Ripples
Tides
I mean this filter board:
http://mutable-instruments.net/shruthi1/build/dsp
By Shruthi Digital XT I assume you mean the XT main board, which I already have.
adam
ok, thanks, thats the same size as the other one so £16
adam
and (deep breath)
ok, working out the costs.
loydb
Put me down for a Module Tester, an Elements, and a Tides please.
adam
and (deep breath)
i'll have to weigh orders (or boards) this size individually to calculate postage
adam
ok, or, alrighty smile
timpecter
adam wrote:
and (deep breath)
OK. I should probably have made it clear that I'm not interested in the voicecards if we don't get enough interest to order the mobo as well!
Synthsense
Wow, this offer is so tempting, but before I get tempted ( I am an easy DIY Wh*re Miley Cyrus ) I'd like to know what happen with the panels, Are there any FPDs, Greyscale's or anything else?
adam
timpecter wrote:
adam wrote:
and (deep breath)
thats ok - feel free to drum up interest in ambika wherever you can wink
Page 1 of 43
