Envelope Follower PCBs (Do they exist?)
valis
aliens killed bigfoot
Post by valis » Fri Feb 26, 2010 12:46 pm
I really don't want to buy a Doepfer A-119 and convert it into my format but as far as I can tell, nobody sells an envelope follower PCB. Am I correct? I know Ray Wilson sells an envelope follower with a filter but that's more of an effect than a control module.
I read in the archives about some circuits that may do the trick but it seems like this PCB should exists somewhere. Am I missing something?
tragedybysyntax
Banned until Restitution Made
Post by tragedybysyntax » Fri Feb 26, 2010 12:48 pm
Blacet I/O.... it's what I used. Really cool because you can use the env 1 and env 2 out to shape the signal a bit. And lag on env 2 out! :)
- [ Custom Metalwork ] -
goiks
Hardest Tryer
Post by goiks » Fri Feb 26, 2010 12:51 pm
mmm amplitude follower
viewtopic.php?t=13147
valis
Post by valis » Fri Feb 26, 2010 12:54 pm
Neither of these companies just sells the pcb though, right? I have to buy a kit or partially assembled board?
ooh, thanks for that link. I miss so much here somehow..
goiks
Hardest Tryer
Post by goiks » Fri Feb 26, 2010 12:55 pm
i think you are correct but it would seem preferable to buying an a-119 to take apart
valis
Post by valis » Fri Feb 26, 2010 1:19 pm
goiks wrote:i think you are correct but it would seem preferable to buying an a-119 to take apart
Yeah, you're probably right about that..
tragedybysyntax
Post by tragedybysyntax » Fri Feb 26, 2010 2:10 pm
pssh.... fuck it. Take it apart! Be the first one to chop shop a a-119!
I chopped an Oakley lag and stuffed it in a sequential switch panel. Also an MFB Dual LFO into a frac ear.! :)
Hi5
Post by Hi5 » Fri Feb 26, 2010 2:22 pm
full wave rectifier followed by a lowpass filter with a cutoff around 15-20hz. that is all it is. add a comparator on the output for gates.
you could stripboard this easy.
krisp14u
Oakley4All!
Post by krisp14u » Fri Feb 26, 2010 2:36 pm
Cheers :guinness:
Paul
www.krisp1.com/store/
Fine Modular systems Built in Yorkshire UK EU Planet Earth
numbertalk
Hunnert Buck
Post by numbertalk » Fri Feb 26, 2010 5:23 pm
http://www.oakleysound.com/follower.htm
Ha, oops, Paul beat me to it. I've built the deluxe version of this (with the little lag) and it's awesome.
valis
Post by valis » Fri Feb 26, 2010 7:00 pm
Good info everyone. I have a few more options to consider that I didn't know about.
My DIY modular (rev. 2.0) is finally taking shape and I'm gettting super-excited..
NV
Post by NV » Fri Feb 26, 2010 8:37 pm
The Oakley EFG is about as good as it gets - LEDs for reference, a fast and slow CV output for the envelope follower, a solid gate extractor with a unique response control, and a high quality pre-amp. Everything you need from this type of circuit on one PCB.
