Jürgen Haible (SOST! Tau ... VOCODER re-run!)
sonicwarrior
Post by sonicwarrior » Thu Mar 03, 2016 4:38 pm
sduck wrote:Mouser No. 623-2743002112LF
133 Ohm sounds a bit much. :hmm:
Soundcloud
For sale: Jürgen Haible Tau Phaser (MOTM format)
sduck
experimental use of gravity
Post by sduck » Thu Mar 03, 2016 6:01 pm
I think it doesn't work quite the same way as resistors. If you put one of these beads on your DMM it reads 0.2R. I think it's frequency dependent or something. There's another thread here (or maybe on electro-music.com, it's been a while, I can't remember) where there was some debate along these lines, and one of our esteemed designers (maybe Jurgen Haible or Ian Fritz?) posted a technical description of what they actually do, and why subbing resistors isn't always the right thing to do. And also why resistors are sometimes the best choice.
sonicwarrior
Post by sonicwarrior » Thu Mar 03, 2016 6:30 pm
Good to know. I think I have some 133 Ohm ferrite beads hidden somewhere because I thought I bought the wrong ones.
Soundcloud
yan6
Post by yan6 » Fri Mar 04, 2016 5:41 pm
I think the ones I use are 135ohm, I have lower ones, around 85ohm if you want the part number for those?
sduck
Post by sduck » Tue Mar 15, 2016 2:28 pm
Zaibach
Post by Zaibach » Tue Mar 15, 2016 3:03 pm
Awesome! :yay: That's some very neat wiring!
DrReverendSeance
Post by DrReverendSeance » Tue Mar 15, 2016 3:07 pm
Dizzying! Looks great. :yay:
fragletrollet
Post by fragletrollet » Tue Mar 15, 2016 4:10 pm
beautiful sduck!
yan6
Post by yan6 » Tue Mar 15, 2016 7:11 pm
Holy shit that looks amazing :hail: simply amazing work!
I was going to pm you for wiring advice on how to get around the switching jacks while using bananas; but i see you are using 1/4"
sduck
Post by sduck » Tue Mar 15, 2016 8:33 pm
Thanks all!
You could ask Ralf at random*source - he certainly does a lot of banana stuff. But I don't think there's much if any issues - JH had the CV inputs normalled to ground via the switching lug, but I don't think that's a requirement - it'll probably work just fine without those. The euro adaptor board skips these. The only normalization I used via a switching lug is from the mix out to the VCA input, and you could certainly skip that.
BTW, calibrating the scaling of this thing is a major chore. I just spent like an hour trying to get things close, and thought I was good, until I tried all 3 VCOs together - I can get maybe 3 octaves fairly acceptable, but past that - well, I need to try again. Tomorrow.
livefreela
Post by livefreela » Tue Mar 15, 2016 11:24 pm
yan - i did a 4u of the lvco - no normalization/adaptation is required. simply wire bananas to the "tip" on the header.
Zaibach
Post by Zaibach » Sun Mar 20, 2016 7:05 am
I have to say, the re-release of Jürgen Haible PCBs by Random*Source has increased the size of my setup significantly... Thank you, Random*Source! Too bad that I can't thank Mr. Haible for his incredible work...
elmegil
Post by elmegil » Sun Mar 20, 2016 8:07 am
DrReverendSeance
Post by DrReverendSeance » Sun Mar 20, 2016 8:33 am
Zaibach wrote:I have to say, the re-release of Jürgen Haible PCBs by Random*Source has increased the size of my setup significantly... Thank you, Random*Source! Too bad that I can't thank Mr. Haible for his incredible work...
I love your front panel designs! Really nice work.
yan6
Post by yan6 » Fri Apr 08, 2016 3:31 pm
After three nights of wiring its done :banana: I wish I could take credit for the front panel, but Charlie, The Bad Producer made it and did simply an amazing job :tu:
I have no idea how sduck got all his connectors to sit beside each other. Mine were so tight I could only get two or three of them together before the interference was too tight for them to fit. That is why you will see a section of header missing and wires just soldered to the board :oops:
Just one more small vcf and this box will be complete :bananaguitar:
bezier
Post by bezier » Tue Apr 19, 2016 3:43 pm
I assume no one has tried running the Tau Pipe phaser on 12v?
fomtoberheim
Post by fomtoberheim » Wed Aug 17, 2016 11:02 am
has anyone completed a vocoder yet?
God has particular languages, and one of them is music and one of them is mathematics.
— David Foster Wallace, The Boston Globe, 2003
Techman
Post by Techman » Thu Aug 18, 2016 7:54 am
fomtoberheim wrote:has anyone completed a vocoder yet?
Kinda. It's functionally completed but not cased yet. Just nailed to a piece of MDF.
I took it to Synth DIY UK in Cambridge a couple of weeks ago. Michael Zacherl took this video. Lots of ambient background noise though ...
Zaibach
Post by Zaibach » Thu Aug 18, 2016 10:40 am
re: Vocoder: Does anybody know if there's going to be another run? Missed the first run, and would really love to build one.... :hyper:
The Big Ear
Post by The Big Ear » Thu Aug 18, 2016 2:20 pm
Did you solve the freeze/accumulate switch issue?
GryphonP3
Post by GryphonP3 » Thu Aug 18, 2016 8:50 pm
Wow, holy 40 slider string filter! Would love tto see what that looks like inside!
My cat can eat a whole watermelon ...
diablojoy
Post by diablojoy » Fri Aug 19, 2016 2:39 am
me also I have an original board in my backlog along with some other original haible boards, will get to them eventually .
would be good to see an example of how that one is wired.
It probably wont happen today but if it does it definitely wont go smoothly.
Techman
Post by Techman » Fri Aug 19, 2016 7:12 am
No, I still need to look at that. It's the accumulate that doesn't seem to work as expected :hmm:
fomtoberheim
Post by fomtoberheim » Fri Aug 19, 2016 8:24 am
Sounds great, what's being used to control the pitch?
Techman
Post by Techman » Sat Aug 20, 2016 4:19 am
fomtoberheim wrote: Sounds great, what's being used to control the pitch?
The excitation signal was a Streichfett string synth controlled by a CME xkey 37 keyboard. The source signal was BBC Radio 4 supplied from an IPad. :hihi:
