programmer?
MUFF WIGGLER Forum Index -> nw2s
Author programmer?
rozzbud
hi,
is it possible to use nw2s as a frames/voltage control/pgm4 emulator?
scottwilson
The 'b can do quite a bit, but due to its configuration, it's hard for it to be _exactly_ one thing or another.
The Frames, for example has a set of VCAs which the 'b does not. It would be possible, however to program it to control a set of VCAs in a similar manner...
Same with the pgm4 - There aren't quite enough knobs to do exactly the same thing, but there are already some pretty powerful sequencer programs for the 'b and if you're the programmer sort, it'd be easy to add more.
Hope that helps...
s
rozzbud
thanks
