Author |
multiple miggs |
br>revoltcrews |
br>can we have a lil blurb about how this module functions.
i bought one. looks to be really useful.
but i haven't patched into it. well, because other than the fact that i know
its a passive mult,
the signal flow and patchability are... just not very clear at all. br> br> |
br>Oodo85 |
br>Sorry for the threadromancy, but I just got one of these and I too am curious as to exactly how this module is set up...kinda confusing for a noob br> br> |
br>Infinity Curve |
br>If you patch into the attenuator input it is normaled to both strips of mults IF you don't patch into the first point on either, say if you want to mult a different signal on the 2nd strip, etc.. If you patch into the first mult strip, it is normaled to the second IF you don't patch to the first input on the 2nd strip. Hope that makes sense br> br> |
br>Oodo85 |
br> Infinity Curve wrote: | If you patch into the attenuator input it is normaled to both strips of mults IF you don't patch into the first point on either, say if you want to mult a different signal on the 2nd strip, etc.. If you patch into the first mult strip, it is normaled to the second IF you don't patch to the first input on the 2nd strip. Hope that makes sense |
Shizzle....so which are the outputs? br> br> |
br>Infinity Curve |
br>It's labelled on the panel. The top left jack is the input to the attenuator, with the output beside it. Below this you have mult strip 1 and beside that strip 2. The top jacks on each mult strip are the inputs for each strip. The way the module is wired internally, if you just patch signal to the attenuator input, and nothing to either of the top inputs on the mult strips, the other 8 lower jacks are your multed signal. If you plug a signal into the top input on mult strip one, you get the multed signal out of the 4 jacks below it. Same deal for the second strip, although if you don't patch anything to its top input, you now have the multed signal from the mult strip one on the bottom 4 outputs on strip 2.
The signal flow is shown on the module, that's what those arrows signify.
br> br> |
