Ian Fritz ChaQuO build
Ekofisk
Post by Ekofisk » Mon Mar 08, 2010 5:56 pm
Sorry for the noob question.
I am populating the Chaquo PCB, and all is well.
However, I am currently doing the capacitors and C1-C4 quite confusing to me. I have the right parts, but I don't know which holes to put the legs in, as the cap has two legs, and there are 4 holes in each location.
Not all of the holes seem connected, so it may be logical, but I don't want to fuck it up.
If anyone has done this build, please help!
consumed
International Filter Conspiracy
Post by consumed » Mon Mar 08, 2010 6:22 pm
ive built it but i dont have it in front of me.
http://muffwiggler.com/forum/viewtopic.php?t=1662
do you have a multimeter? connect the capacitor across two holes that are not continuous. or just eyeball the traces.
Ekofisk
Post by Ekofisk » Mon Mar 08, 2010 6:30 pm
So it IS that simple?
It a pair points connected on one side and three points connected on the other. So any one of the two connected via the capacitor to any one of the three?
neandrewthal
full clout y'all
Location: Spending warm summer days indoors writing frightening verse to a buck-toothed girl in Luxembourg
Post by neandrewthal » Mon Mar 08, 2010 6:48 pm
Yeah, It's that simple. You just have to put it in any two holes that are NOT connected.
pugix
Post by pugix » Mon Mar 08, 2010 6:58 pm
The multiple holes are to accommodate different size capacitors.
Richard
https://www.pugix.com
FS: US only - Mutable Instruments Streams
Ekofisk
Post by Ekofisk » Mon Mar 08, 2010 6:59 pm
Thanks a lot!
Also, the BOM list to 22OHM resistors for some optional PS thing?
If this not to be done, are the two ferrite beads supplied with the bridechamber kit for this purpose?
Luka
Post by Luka » Mon Mar 08, 2010 7:17 pm
yup
Ekofisk
Post by Ekofisk » Mon Mar 08, 2010 7:22 pm
Thanks so much, all of you!
frijitz
Post by frijitz » Mon Mar 08, 2010 9:53 pm
pugix wrote:The multiple holes are to accommodate different size capacitors.
Exactly. Just in case folks have large polystyrene caps they want to use. Nowadays, I would just use C0G ceramics.
:grin:
Ian
decaying.sine
Broken <--> Fixed
Post by decaying.sine » Wed Mar 17, 2010 11:37 pm
bridechamber doesn't have the BOM or PDF instructions posted for ChaQuo. Where did you folks find the resistsor/caps/didode/etc key to go from silkscreened pcb location from the resistance and key mathcing in the BOM or documentation?
diodes and caps were easy to figure out but the resistors are a bear without supporting materials.
"I must create a system or be enslaved by another mans; I will not reason and compare: my business is to create." William Blake
"Vactrols ringing, Dude." "Thank you Donny"
frijitz
Post by frijitz » Thu Mar 18, 2010 6:09 am
decaying.sine wrote:bridechamber doesn't have the BOM or PDF instructions posted for ChaQuo.
You should have been emailed the docs at the time of purchase?
Edit: sent by PM
:grin:
Ian
