Saw 2 Triangle Conversion (using ideal diode circuit)
Author Saw 2 Triangle Conversion (using ideal diode circuit)
fonik
yesterday i built this in spice during my lunch brake after reading jim patchell's ideal diode circuit. it will work with falling/rising ramp, even with only positive going ones (that's what i need it for). however, i've had no chance to listen to it right now.
BTW depending on your application/raw material the first trimmer will have to be wired between the rails.
frijitz
Fairly standard idea, as discussed here:
http://electro-music.com/forum/topic-29149-25.html
And Jim certainly didn't invent the ideal diode!
grin
Ian
gde
heres the page for the unfamiliar
http://www.uni-bonn.de/~uzs159/diode_tutorial/index.html
some interesting waveshaping ideas and function blocks on there
fonik
thanks for thelink, that's great, ian. i will try your and tim servo's suggestion with the opamp type.
lol i suspected that. the sad thruth is i still have not read any of the recommended opamp books. shame on me! i know i should, and it would help me...
