possible issue with my sos
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
blungo2
wiggly wiggler
Post by blungo2 » Thu Mar 11, 2010 9:55 pm
It's almost certainly me doing something dumb, but lately it seemed like my sos wasn't really putting out any delay through the either the mix or delay channels. The clean channel didn't sound much different unless i cranked the rate almost fully ccw.
If i patch a plague bearer into the insert though, it comes alive with wonderful delay sounds. I'm running my QMMG out through it. I wonder if it's a gain issue with the QMMG by itself not having enough gain to fully drive the sos?
Any opinions?
flight
The Plague Bearer
Re: possible issue with my sos
Post by flight » Fri Mar 12, 2010 2:29 pm
blungo2 wrote:It's almost certainly me doing something dumb, but lately it seemed like my sos wasn't really putting out any delay through the either the mix or delay channels.The clean channel didn't sound much different unless i cranked the rate almost fully ccw.
Well, the clean channel shouldn't change in sound much from the original input. There may be a little variation as it is not completely isolated from the Mix portion, but that should be it.
Any opinions?
Could you describe this patch in more detail? What is going into the PB? And do you keep the Insert knob all the way CW when not using the insert jack?
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
blungo2
wiggly wiggler
Post by blungo2 » Fri Mar 12, 2010 10:13 pm
Sorry, i meant the mix channel.
It's the output of the QMMG going into the sos then to a mixer and out to the amp.
Hmmm, that might be it. I "think" i had the insert fully ccw when not using the insert, that's probably the problem.... :doh:
flight
The Plague Bearer
Post by flight » Sat Mar 13, 2010 12:26 am
I hope so, keep me posted!
~flight
blungo2
wiggly wiggler
Post by blungo2 » Sat Mar 13, 2010 9:43 am
Thanks for the help! Wil do.
blungo2
wiggly wiggler
Post by blungo2 » Sun Mar 14, 2010 7:19 pm
Yep, that was it. eye r dumb...
flight
The Plague Bearer
Post by flight » Tue Mar 16, 2010 12:53 pm
Nah, not dumb, it's a weird configuration. I'm just happy it's not defective!
~flight
blungo2
wiggly wiggler
Post by blungo2 » Tue Mar 16, 2010 1:37 pm
Me too! It is an awesome sounding delay, pretty much perfect for me.
Return to “Flight of Harmony”
