Mutant Clap - noise osc leak into main output
MUFF WIGGLER Forum Index -> Hexinverter Electronique
Author Mutant Clap - noise osc leak into main output
ilya.n
Hi,
In my Mutant Clap there is a small leak of noise osc into main output, heard as a hiss (changing with pitch change) when outputting at higher levels.
Anyone has the same issue? Is it a feature or a bug of my module?
toneburst
It's normal, apparently, and there's no way to get rid of it.
Apparently it's worse in the DIY version (which I have) than in the pre-assembled module.
a|x
ilya.n
Pretty sad.
I ll try to re-calibrate.
Otherwise i ll put it through a vca to curb the noise...
toneburst
You can minimise the noise by careful calibration, but you won't get rid of it completely.
This was the best I was able to manage with my Mutant Clap DIY build:
https://soundcloud.com/toneburst/mutant-clap-test
a|x
ilya.n
As I understand pre-built modules do not have this problem.
Can it be cheap hardware causing the problems?
Pots, trimmers etc.?
toneburst
I corresponded with the designer about this, and it seems to be more to do with the 3-tiered PCB layout than with individual components. The industrially assembled version uses a single board, and surface-mount components which are much closer together, which makes it less susceptible to noise-leakage issues, apparently. I'm not sure why this is the case...
a|x
ilya.n
Is it possible to get the schematic? It looks like VCA that controls the body of the clap sound is leaking...
Doc L Junior
Hi,
I had a perfectly working Mutant Clap until today. Now I have constant noise from all three outputs and it does not react to any trig signal - no blinking trig led.
I have no idea what could have caused this - nothing special has been patched into it ad I haven't had any power issues.
I would really appreciate if someone could guide me in troubleshooting this one.
So far I have checked the trig in jack but it seems fine. I have also examined all solder joints and gave some of them a reflow.
dancelwerk
mmmmm
