Module current draw information
Digital Audio Electronics - discussion & support.
Moderators: Kent, infradead, governor blacksnake, solidox
governor blacksnake
ant in the afterbirth
Post by governor blacksnake » Sat Jul 18, 2015 6:53 pm
This information will find its way to the website and other resources soon. Modules not in this list will be measured soon - I've moved my test equipment to a different room and haven't put the modules onto that power supply yet.
These measurements assume "typical" use with some of the I/O patched up and many of the LEDs lit. Maximum current draw may be slightly higher. All measurements in mA.
Hertz Donut mk2: +98, -35
Piston Honda mk2: +105, -33
Tyme Sefari mk2: +36, -46
Zorlon Cannon mk2: +90, -20
Polivoks VCO: +48, -53
Polivoks VCF: +11, -10
Polivoks VCA/ADSR: +32, -32
Polivoks Modulator: +30, -30
Lider Suboctave: +10, -24
mt3
Post by mt3 » Sat Aug 29, 2015 9:14 pm
Safe to assume these are approximately "maximum load" type of patches?
i.e., "worst-case scenario" current draw?
Studio-ES
Post by Studio-ES » Wed Jan 27, 2016 4:41 am
Any updates?
How about these:
Black Locust
Malgorithm Mark II
King Slender
Kermit
Double Andore Mark II
English Tear
Villarceau
Post by Villarceau » Wed Jun 22, 2016 6:22 pm
Studio-ES wrote:Any updates?
How about these:
Black Locust
Malgorithm Mark II
King Slender
Kermit
English Tear
Bump (especially for Kermit)
mt3
Post by mt3 » Wed Jun 22, 2016 9:22 pm
I did a back of envelope calculation for Kermit in another thread. Can't recall where...
darylc
Post by darylc » Wed Sep 21, 2016 1:57 pm
I did some consumption readings on a few of the modules not listed thus far.
The Governor okayed me to publish my findings here.
The +12V readings are important one's so i used a Fluke 175 for this reading.
I applied as much positive CV to practically all CV inputs and had LED's/Modes at their most consuming to get the max +12V power draw.
I've rounded figures to the nearest mA or so.
Double Andore MK2: +150, -80
Malgorithm MK2: +140, -20 (All LED's ON) +110, -20 (ALL LED's OFF)
Kermit: +90, -30
Bionic Lester: +70, -50
The aul ghetto test setup...
mt3
Post by mt3 » Wed Sep 21, 2016 2:12 pm
darylc
Fookin' brilliant. Did you notice any change based on load on the outputs? ie using stackables and sending the outs to multiple modules?
darylc
Post by darylc » Wed Sep 21, 2016 2:53 pm
Didn't test that, but there shouldn't be any difference in theory as the audio inputs & outputs are in essence "always on" as opposed to the CV inputs.
1 output multiplied will also just have a voltage reduction and shouldn't impact current in anyway.
mt3
Post by mt3 » Wed Sep 21, 2016 9:25 pm
Maybe my curiosity for fan-out is for modules in general, but specifically for "my first diy build" modules.
mt3
Post by mt3 » Wed Sep 21, 2016 9:33 pm
Except for Bionic Lester (+125, -125), I updated modulargrid.
mt3
Post by mt3 » Thu Sep 22, 2016 3:55 pm
darylc wrote:I did some consumption readings on a few of the modules not listed thus far.
Kermit: +90, -30
Can you detail the Fluke connection?
Ammeter clamp? Or placed in series?
cylaq
Post by cylaq » Thu Dec 28, 2017 9:06 pm
I emailed asking for the King Slender current draw, and they said
+30, -20.
mt3
Post by mt3 » Fri Dec 29, 2017 1:10 am
cylaq wrote:I emailed asking for the King Slender current draw, and they said
+30, -20.
Gracias!
gringostar
Post by gringostar » Wed Sep 05, 2018 1:57 am
MG lists the Double Andore MKI as +/- 225.
Is that accurate or has this been updated somewhere?
mt3
Post by mt3 » Wed Sep 05, 2018 8:47 pm
gringostar wrote:MG lists the Double Andore MKI as +/- 225.
That's a weird one. I checked the changelog and it was like that for a while.
Analoghaven still sells them and lists the current draw as 150mA.
http://www.analoguehaven.com/theharvestman/model2017/
I updated MG and gave it worst-case scenario to both +12V and -12V even though it's probably only for +12V.
:tu:
gringostar
Post by gringostar » Thu Sep 06, 2018 10:54 am
:tu:
:tu: Thanks!
Just starting my system and was trying to stay below the 90% of maximum rated power that everyone suggests. If the Andore Jr is around 100mA +/- and the Hertz Donut MKIII is similar to the Piston Honda MK III I'll be set.
mt3
Post by mt3 » Fri Sep 07, 2018 11:06 am
:tu:
:tu: Thanks!
80% is a better safety factor unless you know all the modules have been spec'd for worst-case loaded scenario (i.e., all blinkenlights on full blast, all inputs active, all outputs active, every jack plugged in, etc).
mt3
Post by mt3 » Sat Sep 08, 2018 6:03 am
:tu:
Well I just noticed postmodular listed it as 225mA:
https://postmodular.co.uk/modules/double-andore/
Return to “The Harvestman”
