FH-1 firmware announcement thread
MUFF WIGGLER Forum Index -> Expert Sleepers Goto page 1, 2, 3  Next [all]
Author FH-1 firmware announcement thread
This thread will serve as a means for announcing FH-1 firmware updates. Please watch this topic for replies if you would like notification of such updates.
Please keep chat to a minimum on this thread - discussion, support requests etc. can be posted as new topics.
Firmware version 1.1 is up.
http://expert-sleepers.co.uk/fh1usermanual.html#firmware
Changes in this version:
* Added legato velocity setting.
* Added LFO phase controls.
* Added scales to the sequencer.
* Added reset menus.
* Added LFO noise and random waveforms.
cannonball swandive
Hey Os, any idea when the update for the midi channel preferences update will be? Where user will be able to control all the cc of an lfo on 1 midi channel.
Version 1.2 is released.
* Added configuration scripts.
* Added smoothing.
* Added calibration.
* Added setting for preset to load at startup.
albedo0point39
Super quick question - is it necessary to upgrade through each version, or is it possible just to skip to the latest? I'm still on 1.0
You can just skip to the latest.
rove74
I am unable to implement the preset at startup function, maybe a video of this?
I have tried a number of different times following the instructions in the online manual and the FH-1 still doesn't start with correct preset (number 1 in this case).
Thanks.
rove74
Thanks so much, got it. I was missing the part about it being menu 3 on LEDs 1-8.
Version 1.3 is released.
* Added global transpose setting.
* Added setting to disable device-specific modes.
* Added inverted gate option in configuration scripts.
* Added optimisations for the LinnStrument.
* Added support for the Launchpad Pro.
NoSix
Hey OS,
Would you mind a quick explanation to this function?
For the Launchpads & Launch Control XL, and the LinnStrument, the FH-1 enters a device-specific mode. This setting forces the FH-1 to not do that, and treat the device as a generic one.
rove74
Where can I download the hex file for this script:
http://expert-sleepers.co.uk/downloads/fh1scripts/expander%20major.txt
Here.
Smais
My FH-1 doesn't seem to recognize my Launch Control XL or enter a specific mode. I've installed 1.3 , I was hoping it would just jump into the cool sequencer set up from your video. Am I missing something, or is the Launch Control mode not out yet?
Does it not do the double flash of all the LEDs when the LCXL is plugged in?
For the sequencer as in the demo, you need to set up the LCXL with the attached config (in user slot 1).
Smais
Yes it does do that. But none of the knobs or faders do anything. Is that what it's supposed to do in device specific mode? Is the sequencer setup separate from the device specific mode? I'm a bit confused: if I have to configure the LCXL itself what's the advantage of it recognizing the device? Sorry if I'm being stupid.
Edit: Thanks for the config by the way, the sequencer is working nicely which is what I was after anyway.
Cool. The device-specific aspect of this is the visual feedback - that the FH-1 sends MIDI back to the controller to change the LEDs.
Smais
Oh I see d'oh! In that case its working perfectly nanners
Version 1.4 is released. Changes:
* Added internal clock generator (bpm-based and tap tempo).
* Added special purpose outputs.
* Added setting to disable tempo-synced LFOs when clock is stopped.
* Fixed a bug in LFO speeds above CC value 120.
* Fixed a bug which caused sequencer A's outputs to update in response to CCs setting sequencer B's steps.
* Changed maximum polyphony to 16 (from 4).
* Whitespace in configuration scripts is now ignored.
* Added support for raw MIDI in configuration scripts.
robbert
Yeah, great SlayerBadger!
deadvolume
Fantastic!
Not a firmware update per se, but I've added a little pdf quick reference guide for the FH-1 menus. You can download it right next to the firmware updates on the user manual web page.
Version 1.5 is released.
* Added the ability to change settings and perform clock actions via MIDI.
* Scripts are now run whever a USB device is attached, not just at power up.
* Added the DEV & RST script commands.
* Added portamento for monophonic MIDI/CV converters.
* Added sequencer glide and gate length parameters.
shreeswifty
maybe i should ask here. I grabbed a Novation Control XL to use with the FH-1 can you show me how to enable the proper user specific mode please?
How can one tell what firmware is current on the FH-1?
Page 1 of 3
