Wiring cliff jacks
MrTea
Reptilian Brain
Wiring cliff jacks
Post by MrTea » Wed Mar 17, 2010 4:02 pm
Ok, so I got my panel and jacks for doing my first DIY multiple. Apart from a a bit of soldering at school, i'm pretty much a beginner, so please excuse my dumb questions. :hihi:
I've drilled my holes and mounted my jacks and now i'm down the wiring. I understand the principle of how to wire it up but everything I've read refers to the jacks having three lugs. Mine have 4. Should I wire up all 4 together or should I be missing one out? If so which one? I don't know which is the ground, sleeve, tip etc - how can you tell?
the bad producer
Post by the bad producer » Wed Mar 17, 2010 4:16 pm
As you look at the top of the jacks, with the socket pointing towards you, the bottom right leg is ground (sleeve), the top right leg is signal contact (tip), the top left is the tip switch, and the bottom left is the switch for the ground lug...
So basically (unless you want a switched multiple) ignore the two left legs...
If it helps I could post up a pic?
Charlie
MrTea
Reptilian Brain
Post by MrTea » Wed Mar 17, 2010 4:54 pm
Hey man, thanks for the info - I appreciate it.
I think i'll be ok without a pic but thanks. I'll wire up one and see what happens. If it doesnt work i might hit you up for a bit of troubleshooting :hihi:
the bad producer
Post by the bad producer » Wed Mar 17, 2010 5:02 pm
cool... I should have said (you may know this, so forgive me if you find me patronising!) just connect all the ground legs together (front right) and all the tip legs together (back right) but don't connect the one to the other (ground to tip)....
MrTea
Reptilian Brain
Post by MrTea » Thu Mar 18, 2010 3:58 am
Thanks man, I appreciate it. It's not patronising at all. Like I said, I'm just starting out, so it's great to have as much info as possible so I don't fuck it up :hihi:
