beads?
falafelbiels
still learning to wiggle
beads?
Post by falafelbiels » Fri Mar 19, 2010 7:53 am
Hey there,
So I'm building some stuff, among which a CGS VCS and I don't have any ferrite beads. How do I keep forgetting to order these I don't know. I never even used a single bead in any kit because they seem to work with small resistors too. Most CGS build documents say:"ferrite bead, or 10 Ohm resistor" or something like that, maybe 22 Ohm, whatever.
Well now the VCS is the first one that doesn't say that. I assume it can't hurt to stick a resistor in there, but wonder if the value is very significant. For now I'll stick in a 22 Ohm, but if any of you guys know better, please chime in...
kind regards,
Niels
ndkent
Post by ndkent » Fri Mar 19, 2010 8:15 am
Anyone have a U.S. catalog # handy for something CGS suitable?
astroschnautzer
Post by astroschnautzer » Fri Mar 19, 2010 8:38 am
I have bought these: http://fi.mouser.com/ProductDetail/Fair ... 52bA%3d%3d
They where suggested somewhere but it seems they are 68 ohms and the the cgs boards fit with bigger beads, these are quite small....
sduck
experimental use of gravity
Post by sduck » Fri Mar 19, 2010 9:26 am
I use these - mouser part # 623-2743002112 for just about anything that calls for ferrite beads.
amphonic
Post by amphonic » Fri Mar 19, 2010 10:51 am
Thanks for the mouser part # :tu:
daverj
Vintage Video Wiggler
Post by daverj » Fri Mar 19, 2010 11:30 am
I use these a lot:
http://search.digikey.com/scripts/DkSea ... P9818BK-ND
Don't be fooled by the "resistance" value given for a ferrite. Their DC resistance is virtually zero. The resistance value given is the resistance at a specific frequency (usually up around 100MHZ). That's the key to them doing what they do. They pass DC without change just like a piece of wire, but have resistance at high frequencies.
falafelbiels
Post by falafelbiels » Fri Mar 19, 2010 1:24 pm
So they do smoothing? aha...
I remember finding some beads in some other thing I cannibalized some time ago. Since no value is given by Ken I guess I might as well try these huh?
cornutt
Fig juggler
Post by cornutt » Fri Mar 19, 2010 7:19 pm
Yeah, give 'em a try. For audio applications, the specific value of the beads doesn't matter much.
Sequence 15 -- sequence15.blogspot.com
falafelbiels
Post by falafelbiels » Fri Mar 19, 2010 7:23 pm
Now where did I put those? :hmm:
Dave Kendall
Set The Controls . . .
Post by Dave Kendall » Sun Mar 21, 2010 4:32 am
Hi guys.
PC cards and mother boards heading for the recycle plant can sometimes be a good source for ferrite beads. Older dead A/V gear often has quite a few on the boards..
As they're passive, I guess there's not much that can fail on them.....
Free parts are cool :)
cheers,
Dave
Want to Buy: KURZWEIL KSP8
"Everything in moderation, including moderation"
