MB808 PCB
ganchan
Post by ganchan » Wed Dec 23, 2015 11:35 am
Barcode wrote:Really nice ganchan. Do you plan on adding a LCD to your board?
yes there is space there to put an lcd :hihi:
ganchan
Post by ganchan » Thu Dec 24, 2015 8:30 am
piccl wrote:Bug by looking at your board and comparing it to the composite they look to be quite similar. It's too bad the composite is missing the mixer I was getting kind of excited.
I have found images of the mixer doug had for v3. I wish I understood electrical engineering more so I could get this to work. I wonder if I asked EE university student, if they would be able to help me.
i have the mixer in place and routed, it needs to be double checked btw.
ganchan
Post by ganchan » Thu Dec 24, 2015 8:35 am
jarvis wrote:Looks great, ganchan! I'm interested to see how that works out for you.
And the pots line up! It's the little things... :hihi:
Yes pots are perfectly allined, it tooks me some time to figure them out, make the right grid calculations, and than repositioning all the items on the board, but the result is perfect.
The problem is if we'll find the pots with that pinout, but seems that we have a source.
G.
ganchan
Post by ganchan » Wed Jan 13, 2016 11:03 am
A quick update:
https://db.tt/RYLUdhSn
+5v +15v RC SC Accent Trigger Core: traced, some traces need to be wider.
I'll start instruments tomorrow.
G.
Barcode
Post by Barcode » Wed Jan 13, 2016 11:08 am
Nice! Looks good.
Altitude909
Post by Altitude909 » Wed Jan 13, 2016 12:13 pm
Provision for a switching 5V regulator, no need for a linear one and that badboy gets HOT
ganchan
Post by ganchan » Fri Jan 15, 2016 4:14 am
Altitude909 wrote:Provision for a switching 5V regulator, no need for a linear one and that badboy gets HOT
Nice, i'll take it into account!
G.
ganchan
Post by ganchan » Sun Jan 17, 2016 11:22 am
Board finished.. quite so.
It needs some finishing about power traces, documents, etc.
https://www.dropbox.com/s/le32ngw4efe25 ... 0.png?dl=0
There are a lot of improovements that i can make on the board, i've just finished tracing to check everything.
Most of them are wierd traces runs that can be simplified and changing the DIN DOUT pinout connections to make them more colsed to the destination.
I'd like to brig back the instrument pot.
Starspawn
Post by Starspawn » Sun Jan 17, 2016 12:15 pm
G.
The switched pots? are aligned by the top side of pot, but not by where the actual shaft will be? Or am I looking at it wrong?
ganchan
Post by ganchan » Sun Jan 17, 2016 1:14 pm
G.
At this resolution it seems so, but they are alligned by the center of the shaft.
G.
ganchan
Post by ganchan » Wed Feb 03, 2016 1:58 pm
quick update, the final setup, if anyone interested..
https://www.dropbox.com/s/1rn6nv6n1079s ... 6.png?dl=0
kid303
Post by kid303 » Sun Oct 21, 2018 4:27 am
are these files still available as the dropbox link is no longer valid.
