Nonlinearcircuits Mouser carts
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page Previous  1, 2 [all]
Author Nonlinearcircuits Mouser carts
flab
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=e4b7e cf197 but double check
rompersgohard
Awesome! Thanks flab
EarlJemmings
Just made up a Brain custard cart- minus pots
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=1d3f4 92fe7
elcoco
Anyone have a cart for TRIAD? If not I'll make one and post it.
*edit:
Made a cart for Triad , doesn't include pots or sockets.
EarlJemmings
Made up a cart for Squid Axon - again, minus pots. And be sure to add some extras of the resistors, just in case.
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=48400 7274a
DonaldCrunk
here's a cart for Doof, minus pots/jacks!
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=ba9d 4dec95
as well as the Dual OTA VCO, minus pots/jacks/tempcos - i have not double checked this one yet but it should be correct.
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=ca79 aed616
flab
hey,
maybe some of you has a mouser cart for
"multiband dist prossesor"
and for "serious filter"
would be a great time saver
thanks
Plockroy
Anyone has a mouser cart for Triad?
flab
multi band dist http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=3049e bf6f8
serious filter http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=7af33 88cd6
PS no pots, headers, sockets, trimpots, and such! all smds are minimum 10 in the cart as is cheaper to get 10 than two! please double check before you order,
Virgil
Could someone please post the mouser cart for the neuron/diff-rect again? Unfortunately the link to the cart posted here is no longer accessible. Thanks a lot!
flab
that was mine , but looks like is not in my mouser project manager any more, so i can not send a link,but... is a really small project with few components -should be really fast to make one yourself
Virgil
You are right, shouldn't be that complicated. However, I haven't put together any cart so far since I'm just starting out with DIY.
So I guess this might be a good exercise and hopefully someone could quickly check my cart for the Eurorack PCB:
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=4e0c3 69369
Pots and jacks are missing. Can I use the thonkiconn jacks? And some 9mm Alpha pots with 15mm shaft length?
Thanks! :-)
flab
the mouser cart looks ok,the size of the resistors you choosed is a bit smaller than the ones i use.the order should be fine, thonkiconn jack will work, and every 9mm pot should do,almost!where are you buy your pots and jacks from?maybe you can get you ic sockets, headers from there for a better price! (if you place more than 30 pounds orderyou get a free shipping.)
torrez.eddie
Curious if anyone has a mouser cart for BadumTiss- I searched through all of the archives and didnt find one, but I still could have overlooked it. If nobody seems to have one, I'll make one and post it myself. Thanks!!
P8ntbrush
Just ordered the Pcb and panel for the null a2 if someone has that cart it would save me a bunch of time Guinness ftw!
da3v
I see a BOM at http://www.sdiy.org/pinky/data/data.html but this is my first stab at an SMD project, and it would be great if I could remove "ordered the wrong parts" from this particular learning curve.
-Dave
atari5200
Are the LEDs for the Flip Flop Chaos module 3mm or 5mm? And do they need to be superbright?
EDIT-
it's 5mm, FYI thumbs up
kevin0
thenormanconquest wrote:
Dual LFO with Difference Rectifier-
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=2ca51 c8e88
This seems to be missing the two diodes? In the BOM they are just listed as Diodes... Anything I should look out for for these?
EDIT: I think 1n4148 will work based on: http://djjondent.blogspot.ie/2015/11/nlc-2-x-lfos-build-notes.html
andrewF
yep 1n4148 are perfect
Glad you found Jono's pages, his build guides are excellent
satori
Does anyone out there have a cart for the Bindubba sequencer?
dan_k
Anyone have a mouser cart for the Ian Fritz Hypster?
More smt than I'm used to but thinking of taking a swing at it.
brandonlogic
hi, does anyone have a Dual Timbre cart?
thanks!
andrewF
Sorry I don't have the carts myself as i rarely buy from Mouser.
One thing you will find is Mouser are out of stock of many values of 0805 capacitors and will be for a long time like 2019).
Funnily, or not really funny at all, the best source atm is ebay, shipping is slow but at least sellers have stock.
Tayda still have 0805 caps too, but no 10uF, if it is just for decoupling (the caps are located next to the power connector), you could sub in 1uF which Tayda have.
Page 2 of 2
