iProgramCard USB MIDI control from Max
darrenji
Post by darrenji » Wed Oct 28, 2015 12:37 am
For anyone who's interested in controlling the iProgramCard from Max via USB MIDI instead of WiFi, I just built an external that does the necessary OSC message format translation. Right now it's MacOS and 32-bit only, but I could do a 64-bit build if anyone needs it. The external and test patch are attached, as well as the previous Max Easel control patch for reference.
cheers,
Darren
MaxMIDIExternal1_01.zip
(11.21 KiB) Downloaded 32 times
Max Easel OSC v2.zip
(21.63 KiB) Downloaded 18 times
kitchentone
Post by kitchentone » Wed Oct 28, 2015 2:05 am
Cool , but the iPadeasel app is always don't work on ipad3 ios9 for long long time ... :bang:
Drillionaire
Post by Drillionaire » Wed Oct 28, 2015 2:20 am
kitchentone wrote:Cool , but the iPadeasel app is always don't work on ipad3 ios9 for long long time ... :bang:
If you use Max/MSP and this external object, you can just connect the iProgram Card to your computer via a USB mini cable and avoid the iPad app altogether.
synthi
Post by synthi » Thu Oct 29, 2015 10:59 pm
PC please!!!!!! :waah:
Kymátika studio | facebook | soundcloud
Recording - mixing - mastering
kitchentone
Post by kitchentone » Fri Oct 30, 2015 4:57 am
yes it's cool , but for me it 's interesting to use the ipad and iprogram card without computer.
phutureboy
Post by phutureboy » Fri Oct 30, 2015 2:38 pm
Great stuff, thanks !
FS: EMS Analyse Filterbank B1-II | EMS AKS | RSF Expander I & II | PEARL Syncussion SY-1 | KORG MS-20 | KORG SQ-10
synthi
Post by synthi » Thu May 25, 2017 11:25 am
Please can you port the MIDI external for PC??
tommyecho
Re: iProgramCard USB MIDI control from Max
Post by tommyecho » Sat Sep 09, 2017 1:03 am
darrenji wrote:For anyone who's interested in controlling the iProgramCard from Max via USB MIDI instead of WiFi, I just built an external that does the necessary OSC message format translation. Right now it's MacOS and 32-bit only, but I could do a 64-bit build if anyone needs it. The external and test patch are attached, as well as the previous Max Easel control patch for reference.
cheers,
Darren
Thanks darrenji! I've been using the music easel max patch with OSC and it's a lot of fun. I'm trying to use the midi external, but I'm having a problem. I have it connected via a USB midi cable, but the midiout object doesn't recognize it as a possible output destination. Any advice?
Tom
Leoespejo
Post by Leoespejo » Sat Sep 09, 2017 3:36 am
kitchentone wrote:iPadeasel app is always don't work on ipad3 ios9 for long long time ... very frustrating
Uff..... Shame on BEMI.
Max and Easel that's a pair made in heaven.....
Drillionaire
Post by Drillionaire » Sat Sep 09, 2017 1:16 pm
cheers,
Darren
Tom
Is the iProgram Card showing up in the Audio MIDI setup? (Or some equivalent if you're using windows)
You might need to follow the steps in the manual to load the MIDI firmware on the USB MCU. There's a chance it shipped with the USB serial firmware on that chip.
It's on page 11 of this document.
https://buchla.com/guides/iProgramCardManual.pdf
Feel free to PM me if you've got other questions and/or that doesn't work.
tommyecho
Post by tommyecho » Sat Sep 09, 2017 1:44 pm
Drillionaire wrote:
cheers,
Darren
Tom
Thanks for your helpful response, drillionaire. I started to look into the firmware update, but then I realized that I was using the micro usb port, rather than the mini usb port. I found a mini usb cable, and now it works great! As I had hoped, it is better than OSC when sending polyphonic streams of data, so this is really quite useful! Any ideas on what the micro usb port is for?
Thanks again :nana:
synthi
Post by synthi » Sat Sep 09, 2017 2:08 pm
hmmm... no iProgramCard firmware in the download section at Buchla.com :hmm:
Drillionaire
Post by Drillionaire » Sat Sep 09, 2017 2:15 pm
tommyecho wrote:Thanks for your helpful response, drillionaire. I started to look into the firmware update, but then I realized that I was using the micro usb port, rather than the mini usb port. I found a mini usb cable, and now it works great! As I had hoped, it is better than OSC when sending polyphonic streams of data, so this is really quite useful! Any ideas on what the micro usb port is for?
Thanks again :nana:
The micro USB port is for uploading firmware to the AVR32 chip that deals with communication between the WiFi chipset and the ATMega.
synthi wrote:hmmm... no iProgramCard firmware in the download section at Buchla.com :hmm:
I've attached the latest firmware.
iProgramCard_v46.zip
(35.74 KiB) Downloaded 3 times
synthi
Post by synthi » Sat Sep 09, 2017 2:21 pm
Thanks Drillionarie!
I`m not sure what firmware rev. my iprogram card havr. Is there something new or fixed in this firmware? a kind of changelog??? Mine seem to keep disconnecting from some WiFI APs without reason.
Drillionaire
Post by Drillionaire » Sat Sep 09, 2017 4:09 pm
synthi wrote:Thanks Drillionarie!
I'm not sure about a changelog. This is the firmware that's been shipping since 2014.
synthi
Post by synthi » Sat Sep 09, 2017 4:19 pm
Great! Thanks!! :hail:
Andy3000
Controlling iProgram Card from Max
Post by Andy3000 » Fri Sep 27, 2019 7:25 am
Trying to control iProgram Card from Max 8.
Mac OS: 10.10.5 (64 bit)
iProgram Card firmware version 60 (card is in usb/midi mode)
iProgram Card connected directly to Mac via usb mini (not micro)
Tried the following Max apps:
Max MIDI External 1.01
Max Easel OSC v2
Can select the iProgram Card in Max 8, but no reaction
Don’t have an iPad.
Have not made the "both mode" mod. yet.
Any suggestions?
Best
Andy
